RUNNING boosted 4.8/5.3 guys - LS1TECH
Thread Tools Search this Thread
Old 04-15-2012, 09:21 PM   #1
91sonomast's Avatar
Default RUNNING boosted 4.8/5.3 guys
There is all kinds of talk about the big boost 4.8 and 5.3 builds but I don't see very many people actually doing it or that are done including myself. I wanna see how many people have actually got their boosted 5.3 on the road and running.
What engine? What's done to it? What size turbo are you running? Meth? How much boost are you making? How much timing are you running? What kind of hp are you making or track times? Just trying to find some people that have it done and see some end results, this is a big idea since the Hot Rod issue but like I said, haven't seen many people actually doing it and finishing it.
91sonomast is offline   Reply With Quote
Old 04-15-2012, 09:33 PM   #2
1fast bird's Avatar
Do some searching. There are a bunch of guys running boosted 4.8/5.3's with crazy results.
Here.....
http://ls1tech.com/forums/forced-ind...-fairmont.html
A year ago today I took the stock shortblock record...
1fast bird is offline   Reply With Quote
Old 04-15-2012, 09:39 PM   #3
stangtrader's Avatar
Not 5.3 or 4.8 but I am running a stock lq4 in my camaro. I'm on 10lbs with the on3 Turbo on a rearmount setup. I'm tuning the car myself so no dyno numbers but guessing around 500rwhp from the car I ran last night. I'm running 17.5 degrees of timing according to my data logs with commanded 20. No Meth on straight pump gas. I'm about to install my mbc up and start turning it up to around 18psi
stangtrader is offline   Reply With Quote
Old 04-15-2012, 09:58 PM   #4
a4ls2goat's Avatar
do some research man.
plenty of people out there making good power and running good track numbers on stock motors.
i just installed the meth on my 4.8 and will be getting tuned on the next couple of days on 16psi on a GT45.
a4ls2goat is offline   Reply With Quote
Old 04-15-2012, 10:38 PM   #5
Moderator
600rwhp is not hard to do through an auto ive done it many times.
gen3 or gen4 4.8 decent turbo 20lbs of boost on methanol 15-16deg of timing depending on cam and heads, gets the fastest mph, my friends 4700lb truck goes 126.50mph
denmah is offline   Reply With Quote
Old 04-15-2012, 10:54 PM   #6
Moderator
Old 04-15-2012, 10:54 PM   #7
Moderator
Old 04-15-2012, 11:05 PM   #8
5.3 ls7 cam,ls9 gaskets, arp rod and head bolts, and some good spring. on3 76mm turbo .81 ar, th400 , not big boost but 500rwhp and 690rwtq on 9.5 lbs on pump. they said i was good up 12 on pump. dont know the timing tho but could find out
yenkm68 is offline   Reply With Quote
Old 04-15-2012, 11:27 PM   #9
Moderator
you can certainly make more power on pumpgas with methanol, unless you are out of injector.
Old 04-15-2012, 11:30 PM   #10
Moderator
the fairmont is a 01. 4.8l it has a stock head, and a ported ls1 head (totally different heads but its what i had laying around, the one header bolt was so fucked up i drilled the head fucked up, got pissed off and just pulled the head and swapped it, used a USED 5.7 head gasket and ARP bolts, i run 12deg, 20lbs of boost, wawa92 pumpgas with 70% methanol water mix and she is retarded, i took it to the track and it went 11.30 @ 128.8mph on 14psi leaving like i was going to get groceries, didnt make boost till 100ft out, 2.0 60ft.
went 102 in the 8th mile lol
i could do at least 16deg on this motor on 20lbs since thats where our truck seems to mph the best...
that is the same setup, zr1 cam 08 4.8l, stock heads, 20lbs of boost(22 when the converer locks) methanol 70% 16deg of timing in it. 12.0 AFR average.
Old 04-16-2012, 09:35 AM   #11
2005 L33 5.3, 224/228 cam, Lunati duals, LS9 gaskets, ARP head studs, PT7675, 4" downpipe, 16psi, 17 degrees timing, E85, 11.5 AFR, 824 flywheel hp.
LS1NOVA is offline   Reply With Quote
Old 04-16-2012, 10:18 AM   #12
pwrtrip75's Avatar
Back in 2006 I built one for my Nova. Stock 5.3L MPGT45, 317 heads (mistake), 224/224 .580/.580 112 cam (spare laying around), TH350 TCI streetfighter. I ran 15psi + 50hp nitrous. 93 octane.
Home made intercooler. It blew through the converter about 1000rpms... but calculated out to 640whp. Ran for 3 years reliable, driven all over, and beat severly.
Finally spun a rod bearing.
pwrtrip75 is offline   Reply With Quote
Old 04-16-2012, 11:01 AM   #13
Buddy of mine slapped a 5.3 in his GT91 turbo'd C10. Stock bottom end, just regapped the rings, head/main studs, and ported 317s. Stock truck intake. He's running around 20lbs I think on e85. Spools well on the street. It was a built iron 370 before, something happened and it hurt the motor at the track, thus the reason for the 5.3.
http://www.youtube.com/watch?v=yjM3WCSHtuI
westtexasbuff is offline   Reply With Quote
Old 04-16-2012, 11:49 AM   #14
91sonomast's Avatar
I've done a decent bit of research and found some of these projects and results but was looking for more than a few cases. Glad to see these setup's are living up to the hype. westtexasbuff- I'm doing a build very similar to your friends, I'm regapping the rings, ARP rod bolts, ARP studs in the mains and heads, new bearings, 241 heads, and a 70-76mm turbo. Mileage on the motor currently unknown, little rust in one cylinder, going to hone it and hope for the best lol. What do you base your ring gap specs. off of? My main hold up is the victim of the setup needs work.
Keep posting if you have experience with it.
Old 04-16-2012, 06:32 PM   #15
trav-tech's Avatar
04' 5.3L 76mm turbo @ 16psi 690whp vp110 fuel 60lbs injectors 95% duty cycle (maxed out) 232 dur .560" lift 114lsa cam. heads and gaskets, bolts untouched. arp rod bolts clevite rod bearings, mellings hv oil pump. its a drag car only but have about 60-70 passes on it. soon it will be getting 80lbs injectors and going to open gap on top ring and do arp head bolts and a set of 243's and bump to around 20-21psi boost. going to shoot of 800+whp or bust.
trav-tech is offline   Reply With Quote
Old 04-16-2012, 10:39 PM   #16
chevellepowered's Avatar
travtech what turbo u using..brand i have simlair setup..
chevellepowered is offline   Reply With Quote
Old 04-16-2012, 11:54 PM   #17
trav-tech's Avatar
Unfortunately I really dont know much about the turbo. I got it second hand (was on a 2.1L four cyclinder that rand mid to high 7's 1/4mile) it is stamped "TEC" on the comp housing. 76mm wheel cold and p trim hot with a 1.15ar t4 divided tang housing.
Old 04-17-2012, 12:14 AM   #18
91sonomast's Avatar
I think TEC is Turbo Engineering Corporation.
Old 04-17-2012, 12:39 AM   #19
trav-tech's Avatar
Yeah I went to their site and could not find much info. I should call them and see what They can tell me about it. It's like 12 years old though. The best part is that I got it for $250 and it had a brand new cartridge in it. It had a 1.52ar housing on it when i got it i put the 1.15 on that I had laying around. I think i'm going to try it with the larger housing when change the heads.
Old 04-17-2012, 01:53 AM   #20
See my sig, both cars are on e85
skinnies is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
big blocks in 4th gen f-body blwn95z Small Block & Big Block Chevy Specific 24 01-28-2016 09:30 PM
What kind of power have you made on an L33 5.3 aluminum block? BlackSS4thgen Drag Racing Tech 7 12-22-2015 03:19 AM
How long did your "Long/Short Block 4.8 5.3 5.7 6.0 6.2" last Boosted? Vcious04 Forced Induction 21 04-05-2013 12:44 PM
What should it run? Wicked69 Forced Induction 7 03-30-2012 10:27 PM
What power are you making with your 5.3, and how much boost did it take? hdkarmy Forced Induction 115 02-23-2012 01:20 AM
Tags
10, 48, 53, arp, bolts, boost, boosted, build, e85, engine, head, injectors, lbs, ls1tech, stock, studs, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
