Fireball Twin Turbo Third Gen Camaro Build thread
hmmm...wolfe minitubs fit pretty well from what I read on thirdgen.org
Looks like I may go with a BMR k-member with LS1 mounts and a pinto steering setup (manual steering)
QA1 double adjustable struts up front (coil over)
AFCO DA shocks in the back
probably will roll on a 275/60/15 drag radial tire
will probably custom build my own moly cage...
Sounds like another racecar?
My 3rd gen uses shorter racecar (Koni/Lamb) struts that still bolt into the same stock location. I moved the wheels inboard slightly to lower it and added caster.
Cool build.
Kurt
Cool build.
Kurt
