BIG boosted 5.3s: come In and list ur setup!
my fuel pumps came back friday, got a startup tune from brian at DTM last week. As soon as i can catch a break at school ill head home to wrap it up.. if all seems good(no leaks) then ill schedule a tune for mid May.
What are the best factory heads to run on a boosted 5.3? Whatever I choose will get a mild port job.
My build will be like the op's. Plan on an 88. I bet one can make more power with an 88 on a smaller cubed engine. That's why I am using the 5.3 versus the 6.0.
I have a gt47-88, 6" inlet, t6, 3.5" comp outlet, 5" downpipe. 1.08a/r, race cover. Rated for 1600hp. It will b latch, I know, but I'm hoping the rossler 400 and Neal chance converter will keep it lit.
I have the 862 heads now silver t. But I have to go to a aftermarket casting. I am looking at the new edelbrocks. They're only 1,079$ from tsp and they say they have a 5/8" deck
Not too many chiming in on there builds. Come on 5.3 guys...
I will post my buddies 5.3 setup we recently did.
All stock 2001 LM7 5.3 (unless noted ... its stock)
Engine:
60lb injectors
Arp rod bolts
LS9 head gaskets
re-gapped stock rings to .030"ish
head studs
'02 zo6 cam
PRC dual spring
moly push rods
2 bar map
King bearings (rod main)
Turbo:
PTE 74mm
JGS 50mm WG
50mm BOV
ebay from mount
Snow meth kit/ 93 octane
Th350 and 8.8 rear (3.08's)
DynoJet Dynoed 554whp & 574wtq @ 12 psi (eddy brake was not working and would only spool 12psi) -- runs 15 to 16 psi on the street. (Guessing somewhere in the 6's whp @ 15to16psi).
No track time yet. But it feels really strong. (3000lbs - '87 S10 Blazer)
Engine:
60lb injectors
Arp rod bolts
LS9 head gaskets
head studs
'02 zo6 cam
PRC dual spring
moly push rods
2 bar map
Turbo:
PTE 74mm
JGS 50mm WG
50mm BOV
ebay from mount
mine isn't finished yet, but motor is going together next week,
stock rods, pistons, crank (01 lm7)
arp head studs, main studs, rod bolts.
gt4788 1.10 a/r t4 3.5" downpipe
317 heads
slp oil pump and billet timing gear
02 z06 cam (yellow springs for now)
0.030" ring gap stock rings
105lb/hr injectors and some E85 should do the trick'
currently waiting on a 99 pcm and a 3 bar map to finish this thing up.
317 heads
#32
Forged 365 kicked the bucket, so in went an '04 5.3 with 160k+ miles.
New parts: Melling oil pump, ARP rod bolts & head studs, LS9 cam & head gaskets.
Old parts: 317's w/PRC dual extremes, TBSS intake, GT-91mm front mount, Magnafuel pump, ID2000 injectors (E85). 5.3 just got rings gapped, and cleaned up. Original bearings, rods, pistons & crank...you get the idea.
The 365 pushed my '68 C10 to 141 mph in 1/4 @ 3,850# race weight breaking loose outta da hole. Around 21-22 psi.
Fast forward to 5.3 install, and didn't adjust tune, saw 20psi. That sumbitch pulls hard. Hard as the 6.0, no. Damn close? Yes. Close enough that I probably won't build another shortblock, when 5.3's are $250. Might switch to an aluminum block just to save weight.
Lag with the 6.0 was none. With the 5.3, very slight. Backed it down to 17 psi to get the weight transfer dialed in, and will be starting soon to tune up to 23-25 psi.
#33
Anyone have personal experience with a cast crank and forged rods plus pistons? How much abuse will the stock crank take. I hear conservative is 550hp max?! If you can say otherwise, how much and how long (miles)
#35
I'm getting ready to pull out a 4.8L motor that has had gallons of E85 + 19 PSI of boost through it...stock rotating with 317 heads, dual springs.
I am going to be putting in a completely stock 220K mile 5.3 L to see if I can hit low 10's (I have a M6 and traction issues).
These little motors are great for power in stock form.
The key is good tuning, period.
#36
Good info here.
Looks like a 5.3 can be safely bored to 3.902 or so which would make it possible to use ls1 pistons, rods and so on. I may go that route. Undecided about using stock crank or a stroker forged one.
#40
I am far from BIG boost, but I put down 609 @ 10lbs on a dyno dynamics through a little 67mm . Here is a dyno clip from yesterday.
http://www.youtube.com/watch?v=D7-m2We2qPg
Here is an idle clip from when it was open down pipe.
http://www.youtube.com/watch?v=ebsZLuPWeHw
