Procharger on a high compression motor..
Hey guys I have a built 12.3-1 403ci LS2 in a built 2002 Z28 Camaro. I know fo a FI motor the compression should be about 8-1 compression but is it possible to run a supercharger with low boost on a high compression motor? Was thinking about installing a charger on my Camaro but didn't want to have to go back into the motor and replace the pistons if I can run low boost.. Thought please..
boost, compression, compresson, e85, high, higher, low, ls1, ls2, motor, motors, procharged, prochargedmotors, procharger, put, run, sale
