One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
Old 06-14-2012, 03:59 PM
  #41
LS1NOVA's Avatar
Originally Posted by 94 slow
Thanks for getting back to me. Everything looks good. I hope the home made tru-turn works out for you. When do you think the car will be running?
Its running, just need to get some street time and its been raining. i
Old 06-14-2012, 07:02 PM
  #42
2002camaroSS's Avatar
Nice, it will be cool to see how it compares to your old setup!
Old 06-14-2012, 07:13 PM
  #43
gnx7's Avatar
One of the nicest Nova's I've seen! Bad *** setup.
home built is where its at!
Old 06-14-2012, 10:26 PM
  #44
typhoon1015's Avatar
when's it hit the rollers again? - let me know.
Old 06-18-2012, 08:33 AM
  #45
gimmeluvin's Avatar
did you get to cruise Sunday at all?
Old 06-18-2012, 12:33 PM
  #46
LS1NOVA's Avatar
I will let you know.
Its only been up and down the road a couple times. I have to pull the transmission as I believe the overdrive roller clutch is messed up and it slips in reverse and od.
Old 06-18-2012, 03:33 PM
  #47
gimmeluvin's Avatar
wow that sounds incredibly dangerous.. well hope you figure that **** out. I have been driving my camaro around a little bit. My intake temps are off the charts.. I need rework some things.
Old 06-18-2012, 03:38 PM
  #48
gimmeluvin's Avatar
haha nevermind that last post i miss read that... Im driving..
Old 06-26-2012, 11:23 AM
  #49
Steve68's Avatar
What size pipe did you use? where did you get the flex joint??
did you look at the F body manifolds, bummer is when I moved into my new house I threw away a set of truck manifolds, damn!!!! it man!
Old 06-26-2012, 01:16 PM
  #50
LS1NOVA's Avatar
The flex is recycled from a GM car V8 crossover pipe. The F body manifolds are very similiar to truck manifolds. The pipe is 2 1/4 OD.
Old 06-26-2012, 09:26 PM
  #51
Steve68's Avatar
Cool thanks, have to stop buy a JY for the flex, remember the car?
a guy on lat G is selling off his turbo parts, might try to buy his headers,
a guy has a 44mm turbonetics waste gate, would this be good for my combo, I'm basically trying to mirror yours, or do I need bigger,
Old 07-01-2012, 08:45 PM
  #52
LS1NOVA's Avatar
The car finally all came together last week and the is running well so we headed down to Ia for the weekend. Dropped the little munchkin off at Gma and Gpa's and went to Cedar Falls Midnight Mania. There were just the right amount of cars. A little of everything. Its really a great deal at $20.
The car was having an issue cutting out after a long pull on 20psi so I backed it down a little to 17psi on the street. At the track it ended up around 19psi with good traction. I also installed a set of caltracs to replace my sweet slapper bars and swapped to Hoosier DOT 335/35/17 drag radials. The first run I put a 10psi spring in the wastegate to establish a baseline and make sure the car was smooth. Timers were not set up right so no timeslip on that. Did a few runs with traction issues and lifted a couple times. 11.10, 10.8, etc. Dropped the tire pressure down to 18 and let the car cool a bit and did the 10.39. Ended up being the best pass of the night. Car slowed a little later to 10.5's around midnight. Track wasnt feeling as good as the dew rolled in and I also took the cutoff cap off which didnt help I guess.
I entered the competition at the end of the night for the top 4 fastest domestics. Me, a red 421cu na stripped S-10, a new CTS-V coupe with some light mods in the low 11's, and a black Mustang with unknown mods running the 8th mile all night. I lined up with the Mustang first, he killed me off the start but ended up taking him up top. Next, ran the S-10 but he got me as it was dead consistent. It was supposed to be a street car event with mufflers and street tires but they let him take the title with open headers. Oh well.
I'll probably go back to the track later this year with more boost and maybe try a few simple things like unhooking the sway bar and trying to build some boost off the line to eventually have my 9 second street car that can also turn corners. Hopefully some others can make it down too.
Heres one video. The Honda in the right lane was my wifes favorite car of the night lol.
Old 07-01-2012, 08:52 PM
  #53
89ROC-Z's Avatar
Congrats Nate! That sounds pretty damn sick compared to that honda lol. Really makes me want to put a s480 or 75 on the T/A...
Old 07-01-2012, 08:58 PM
  #54
FAST LS1's Avatar
Very nice build. I too am on a similar build with a stock short block 5.3L and PT7675. How much does your car weigh and what rear end ratio are you running?
Old 07-02-2012, 07:11 AM
  #55
Steve68's Avatar
nice, moves pretty good, you see my PM,
Old 07-02-2012, 11:08 AM
  #56
LS1NOVA's Avatar
The flex is from a GXP with a 5.3. Unlikely that you will find one.
44mm would work but it really depends on how LOW of boost you want to run. If your going to try 5-6 lbs, go bigger. Mine controls good at 10lbs but prob no need to go lower for me.
Old 07-02-2012, 12:59 PM
  #57
Steve68's Avatar
GXP what the hell is that, prolly right on finding one, not getting the headers, damn,
OK thanks, what to go bigger, 10-12, I'm guessing, thanks for the tech support!!
Old 07-02-2012, 06:43 PM
  #58
Beanslsxnova's Avatar
i feel like your not gonna have to try real hard to get that 9 second pass lol. anyway gongrats man! love the car
Old 07-03-2012, 12:46 AM
  #59
skinnies's Avatar
My precision 46 controls down to 3lbs no problems with my 5.3 and precision 76mm.
Old 07-03-2012, 01:06 AM
  #60
foose04's Avatar
Sorry if I missed it, but is this still a 327 but forged? Thanks
Quick Reply: One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
