Just Another JY 5.3 Build......
Old 04-30-2012, 09:52 PM
BottleFedZ346's Avatar
Arrow Just Another JY 5.3 Build......
I have been working on this for a few months now, i wasnt going to do a build thread but figured, why not......
Setup:
2001 Z28
2003 5.3
Spohn solids
LS6 intake
Ported stock tb
LS2 cam
LS6 springs
Flipped truck manifolds
32x13x4 Fmic
Homemade merge
Homemade DP (4inch)
44mm wastegate
On3 76mm .96
Trans:
Built RMVB Th400
FTI 3500 stall
BMR crossmember
Started out like this
Got the old motor out
New motor put together
All done and in the car
Now time to build the hotside, used truck mani's with v-bands welded on
Crossover/merge being made
Hotside pretty much done
Rad put back in
Also got the FMIC mounted
Bumper cut to fit the downpipe/FMIC
Pretty much how the car sits now
I still have a good amount of parts to gather up before i can turn her over.....
Old 05-01-2012, 08:47 AM
JoeyGC5's Avatar
Nice project and good progression
Old 05-01-2012, 09:22 AM
SPRAYED 01's Avatar
Was there something wrong with the stock ls1?
Old 05-01-2012, 10:36 AM
RedRocketZ28's Avatar
Looks good. Same turbo I will be running. I am anxious to see how it does.
Old 05-01-2012, 11:21 AM
NoGo's Avatar
How's the exhaust fumes with that front exit on the turbo?
Tolerable enough for a street drive?
Old 05-01-2012, 04:11 PM
The motor ran perfect before yanking everything out, I had already planned this build when I bought the car.....
I have driven a few cars with exhaust setups like this with no issues, little loud but that's something I'm used to.....
Old 05-01-2012, 04:50 PM
LCR Camaro's Avatar
My exhaust is the exact same way and on e85 I can't smell it at all and I street drive mine alot. Nice build cant wait to see some videos when its all done.
Old 05-01-2012, 04:53 PM
alexcoreas's Avatar
So your just running this right out of the junkyard right? Stock head gaskets and hardware?
With the exception of the stuff mentioned above.
How much are you hoping to make with the on3 Turbo?
Old 05-01-2012, 05:23 PM
Stock headgaskets/headbolts for now, although i have been thinking of throwing in some head studs just to be safe, as far as set goal im looking for around 600whp, should be plenty for the street.....
Old 05-01-2012, 05:45 PM
alexcoreas's Avatar
We have the same power goals.
I was tossing the idea of head studs as well just to be safe. Looks good and finally a thread that I can follow with similar goals and I'm assuming your trying to make this budget friendly?
Old 05-01-2012, 06:02 PM
HRHohio's Avatar
Also subscribed!!!
Old 05-01-2012, 06:07 PM
a4ls2goat's Avatar
Very good fabricating job.
Should make some good power
Old 05-01-2012, 06:29 PM
SPRAYED 01's Avatar
Why didn't you just use the 5.7 and not loose any cubes? For your level does the iron block really matter?
Old 05-01-2012, 06:43 PM
boostit5.3's Avatar
niceee
Old 05-01-2012, 07:06 PM
Packy's Avatar
Looks good! Nice welds too!
Old 05-01-2012, 09:05 PM
I have about $3500 in the WHOLE setup including the purchase of the car, so yes I'm doing this on a budget.....lol
I didn't do it for the iron block, I did it because the ls1 had a good amount of miles on it, and for what I plan On doing power wise later on the ls1 wouldn't handle it.....
Old 05-01-2012, 09:45 PM
camaroboricua's Avatar
nice build. looks just like what ill be doing...cant wait to see more progress pics...
Old 05-01-2012, 10:35 PM
I'm going to order the coldside stuff this weekend, will post pics when I get it all done!
Old 05-01-2012, 11:00 PM
trav-tech's Avatar
I would'nt bother on the head studs for 600hp. My stock head gasket/bolt 5.3 is holding just fine at 690whp its got about 60 passes at the track. Never even retorqued them.
Old 05-01-2012, 11:48 PM
Good to hear!
I'm more worried about valve float with the ls6 springs then I am about lifting the head.....
Quick Reply: Just Another JY 5.3 Build......
