LS9 gaskets with L92 heads? - LS1TECH
Thread Tools Search this Thread
Old 05-03-2012, 11:58 PM   #1
z28boysteve's Avatar
Default LS9 gaskets with L92 heads?
I have read that the LS9 gasket has a bore of 4.100 and the chamber width of my L92 is 4.125.. Would this matter any? Im talking a big power motor I have 1,000 to the ground from a PT101 at minimum boost (18psi) and blew a cometic the other day, noticed other head was pushing water on all four cylinders, The block feels smooth to the touch where it blew, the heads are gonna get .010"-.015" off the decks as a precaution.
z28boysteve is offline   Reply With Quote
Old 05-04-2012, 07:29 AM   #2
Use them. Lots of guys are using them without problems in pretty much everything, including small bore stuff like the 3.78 bore 4.8 and 5.3. Including me.
LS1NOVA is offline   Reply With Quote
Old 05-04-2012, 11:55 AM   #3
68 SS's Avatar
I used them on my old 408 combo worked great, go for it!
68 SS is offline   Reply With Quote
Tags
71, blown, bore, cometic, forced, gasket, gaskets, head, heads, induction, l92, ls9, nova
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
