Best head gasket for high boost application?
Old 05-05-2012, 07:28 PM
mr_biscuitz's Avatar
Default Best head gasket for high boost application?
As the title says, whats everyone using? Ive used the Ls9 gaskets but havent had much luck with them but most wasnt due to the gasket but tuning. Still curious to what everyone is using. Thanks
Old 05-05-2012, 07:32 PM
RacerXLs1's Avatar
I have LS9 I think it's the most common.. Im curious to see what others are using as well..
Old 05-05-2012, 07:33 PM
HydroStream6's Avatar
Ls9 is going to be the general winner here. I just received my first set yesterday, will be going on the GTO shortly
I've used other GM MLS 3 layer gaskets for years up to about 1000hp and 20psi with decent results too.
Old 05-05-2012, 07:43 PM
I8UR4RD's Avatar
I went ls9. plannin on 750-800rwhp. 1/2 inch head studs on top of it should be super safe as well as the addition of heads with a .750 deck.
Old 05-06-2012, 12:13 AM
Wanting to know what the guys are running making north off 1000?
Old 05-06-2012, 09:40 AM
7 Second Club
Phil99vette's Avatar
How much power do you want to make? Boost is not really relevant. I like the MLS gaskets to 1000-1300hp, after that I like either copper with o-rings or the fire rings from Andreas with a graphite gasket.
Old 05-06-2012, 01:13 PM
Tally TransAm's Avatar
went with cometics for mine. was going to go ls9 but needed something thicker
Old 05-07-2012, 04:52 PM
previously made a little over 1000 with the ls9 gaskets but either due to the tune or the stock heads kept lifting them. Now going with a different set-up and wanted to know, plan on power being around 1300-1400.
Old 05-07-2012, 04:54 PM
when you say o-rings are you talking about the block or the gasket with the rubber o-ring built in? Is there a brand that youve had experience with that is better than others? Thank you
Old 05-07-2012, 05:00 PM
93camaro_zzz's Avatar
I have Cometic MLS gaskets on mine with a little bit of copper spray.
Old 05-07-2012, 05:26 PM
willizm's Avatar
I have the GM 6.0 MLS gasket and pushing about 700whp at 17psi. Not problems thus far, but the next time I pull the heads I'll probably put on ls9 gaskets.
Old 05-07-2012, 11:54 PM
skinnies's Avatar
Find a new tuner, the ls9 gaskets should be fine for you.
Quick Reply: Best head gasket for high boost application?
