Which valvesprings? S475, 5.3, z06 cam
Would the stock ls6 springs hold over 15lbs?
Ideally I would like to run 18lbs. Setup is just a Stock 5.3 with z06 cam and a 1.1 ar t6 borg. The cheaper the better because this is a budget build!
I think your missing the point a bit though. Add in new head bolts/studs head gaskets etc and suddenly this $300 junkyard engine is getting more expensive. I don't want to wind up tearing the whole thing down. Its only got 60,000km so everything should be fresh as well.
