Any Fox Bodies Using C6 Exhaust Manifolds?
I had a junk block sitting in my car with the c6/truck manifolds just to see what I had to work with. I had to remove the heat shield on the truck manifold for the steering shaft bolt up to the column. By the looks of the c6 drivers side manifold it seems like the exhaust would exit right into the steering shaft. Just pulled the motor out last night or I would throw one on for you and snap a picture.
