Boosted 5.3s What rwhp are yall making with what setup?
Old 05-25-2012, 11:09 PM
boosteds10's Avatar
Default Boosted 5.3s What rwhp are yall making with what setup?
As the title says...
What rwhp are yall making on your stock short block 5.3s?
And what heads, cam, intake/tb and form and amount of boost and type of fuel?
Old 05-26-2012, 10:27 AM
chevellepowered's Avatar
stock 08' 5.3 , 228/232 .59x .59x lift 114.. magnum 76mm .. 4l80e stock stall. 12 bolt.
14lbs 550rwhp in 2nd gear pull..dyno jet. 14* timing ..log setup. homemade .. i plan on those ebay turbo manifolds..
Old 05-26-2012, 03:02 PM
A.R. Shale Targa's Avatar
The few I've stumbled across on here usually make 450-475rw with stock or
factory Z06 cam (yellow springs) and 8-10 lbs of boost on 93 octane.
It's almost impossible to keep a boosted LS under 600 flywheel ponies.
Old 05-27-2012, 04:55 AM
Fbodyjunkie06's Avatar
Why a 2nd gear pull?
Old 05-27-2012, 12:25 PM
boosteds10's Avatar
Keep um coming guys.
Old 05-28-2012, 07:02 AM
its in a chevelle.. tuner didnt fell safe with 3rd gear pull niether did i with 3.23 gear... we had it straped down kinda sketchy .my sump was in way of straps..
Old 05-31-2012, 04:02 AM
LSxPwrDZ's Avatar
Just had a Fox Mustang on the dyno the other day with a stock 100K+ mile 5.3 with a single plane tall elbow cam and throttle body with a S475 on 12psi made 565rwhp through a TH400 on my Dyno Dynamics on E85. I didn't get aggressive with timing either, it was only running 12* or so just to be safe cause he was out of injector and pump. Max'd 80lb Siemens injectors out on a Magnafuel 4301 with a base pressure of 58psi boost referenced. He took it to the track and launching it off idle and coming into boost about 60' out on 6psi it still ran a 6.4 @ 114mph with almost a 3000' DA! Raceweight is just over 3000lb's.
Old 06-11-2012, 05:03 AM
S13LSx's Avatar
Damn!! I've got the same turbo going on a cammed L33 in a 240sx witha glide. Was gonna let Anthony Peck tune it but that's a nice trap you got there. might have to get with you.
Old 06-12-2012, 10:45 PM
sw07gt's Avatar
690/690 on 14 lbs, PTE 7675, E85 through a 4L80 and a 9 inch.
Old 06-13-2012, 06:46 AM
Sarg's Avatar
Hoping my 80s will be good for a touch more than 600 hp on e85. If not I guess it will be time to upgrade.
Old 06-15-2012, 05:30 AM
S13LSx's Avatar
Anthony tuned your car didn't he? He said you were at 95% duty cycle with 96lb(@3bar) injectors. What was your base fuel pressure? I just got a S475 and I'm trying to decide on injectors. I was suprized when he said your duty cycle was that high with 96lbers on E85 at that power level on a dynojet.
BTW, you're about to hurt some people's feelings around the 502! Congrats man.
Old 06-15-2012, 12:38 PM
masnart2000's Avatar
My friend made 485 to the wheel on a stock heads and cam motor.
Old 06-16-2012, 08:07 PM
Talon77's Avatar
78 trans am, stock 5.3 bottom end with 30k, custom ground cam, ls9 gaskets, head studs, edelbrock intake, rear mount comp oil less turbo, inter cooler, 20lbs of boost, 759hp/670tq thru th400, and a 9" rear. Done by unleashed performance, tuned by Rob Raymer.
Enjoying the crap out of it, putting a 2 step on it this week and a new fuel pump.
Billy
Old 02-01-2017, 07:48 PM
Cody Preston's Avatar
Default power range
well I'm gonna be swapping a 5.3 into my trailblazer I'm gonna be doing .030 over, forged rotating assembly, voodoo stage 2 turbo can, Sullivan high rise intake, ls2 heads, 80# injectors a1000 fuel system, about what should I make at give or take 12-14 psi? Gonna go with a 9inch rear end also
Old 02-01-2017, 07:50 PM
Default power range
Forgot to sa​y, I'm going with a pte 7675 turbo
Old 02-02-2017, 12:19 AM
chevyforlife's Avatar
2000 5.3 arp head and main studs, 317 heads, ls9 cam comp ct43-78 turbo 18psi threw a 4l80 and 9" with 3.25 gears 26" slicks. No dyno numbers but ran a 9.83 at 139.9 in the 1/4 car weighs 3775 with me in it. Online calculators say it should be around 700-750 to the wheels. Some how still runnin strong for 3 years now
Old 02-02-2017, 07:12 AM
ls1charged's Avatar
what cam?
Old 02-02-2017, 07:52 AM
Restricted User
JoeNova's Avatar
Originally Posted by ls1charged
what cam?
That was like 5 years ago.
Cody, when did Sullivan decide to make anything other than Ford intakes?
Old 02-02-2017, 08:14 AM
ls1charged's Avatar
didnt realize this thread was brought wayyyy back from the dead lol
Old 02-02-2017, 12:12 PM
LS2 67GTO's Avatar
JY 5.3L, truck intake, custom Martin Cam, S475 T6 1.32, TH400, 9" rear
15 PSI made 698 RWHP on pump 91 and meth. Wanted to take it to 20 PSI but boost controller was maxed out and had limited time on dyno. Made 3 back to back pulls with minor fuel/timing adjustments between each. No track time yet but will as soon as winter is over.
Quick Reply: Boosted 5.3s What rwhp are yall making with what setup?
