**Late Model Racecraft 5 Year Anniversary Special Inside on Packages**
June 1 2012 will be our 5 year anniversary here at Late Model Racecraft in Houston Texas. It has definitely been a great and challenging experience these past five years to say the least. This Industry is very hard to grow a successful business with so many competitors and internet sales companies.
I would not have made it this far without my loyal customers and my great employees and I thank you guys for that. You, and the amazing cars you guys let me build is what makes all of the hard work worth it. I attribute my success to my honest work ethic and always delivering a product above and beyond my customers goals/needs.
Enough rambling, Now for our 5 Year anniversary I will be selling all Performance packages at $1k under retail. These are for our turn key performance packages. Most packages do not take more than one week to complete from start to finish. So if you are thinking about shipping us your car, do not worry, we will only have your baby for 1 week.
**C6 ZR1 Stage 1 Package**: $5,999 (Special $4,999
-C6 ZR1 High Flow Supercharger Air Intake Snout 2009-2011
LS9 Eaton Supercharger Front Cover Assembly
-Air Intake Kit for LS9 Supercharger Front Cover
-C6 ZR1 Corvette High Capacity Heat Exchanger Kit 2009-2011
-Professionally Installed
-Forced Induction Dyno Tune
http://www.youtube.com/watch?v=hu6e8bDusCw&feature=plcp
**10/11/12 ZR1 Slayer Package**: $13,999 Special $12,999
C6ZR1 1 7/8 American Racing Stainless Steel Headers
C6Z American Racing X-pipe with high flow cats
02 Extensions
NGK Spark Plugs(Iridium)
MSD 8.5m spark plug wires
Custom Heat Exchanger
Heat Exchanger water pump with connector
comes with 2.6 supercharger pulley
09/11 Corvette ZR1 Harmonic Balancer Kit
LS3 160* Thermostat
LS3 Comp Cam Kit, Comp custom grind cam shaft, comp Double valve spring kit good for .675 lift, Titanium Retainers(custom for ZR1), Spring Seats, Valve seals, and comp chromoly pushrods
Water pump gaskets, Oil pump inlet tube, front cover, crankshaft front seal
LS9 Crank Bolt
Mild to Wild Exhaust Switch
Lowering Bolt Kit
Mobil One Synthetic Oil
Mobil One Oil Filter
Coolant
http://www.youtube.com/watch?v=ecu6ULDRcXs&feature=plcp
**C6 ZR1 REAPER Package STG III** Starting at $19,999
-Email or call for details
http://www.youtube.com/watch?v=H4XVLE31RA0&feature=plcp
http://www.youtube.com/watch?v=IeDjSazHimY
**C6 Z06 Slayer Package** Retail $8,999 Special $7,999
Slayer C6Z Package:
Callaway Honker C6 Cold Air Induction System
C6Z 1 7/8 American Racing Stainless Steel Headers
02 Extensions
MSD 8.5mm spark plug wires
NGK Spark Plugs
C6Z3 Cam Package
All gaskets and seals
ATI LS7 Underdrive Pulley
Gates Belt
LS7 Crank Bolt
LS7 160* Thermostat
F.A.S.T. 102mm Intake Manifold
C6Z Mild to Wild Switch
Mobil One Synthetic Motor Oil
Racing Oil Filter
Shop Supplies
Professionally Installed and Dyno Tuned
http://www.youtube.com/watch?v=yh0LmYHGpX4
**C6 Z06 REAPER Package** Retail $12,999 Special 11,999
C6Z Reaper Package:
Callaway Cold Air Induction System
02 Extensions
NGK Spark Plugs
MSD 8.5mm plug wires
C6Z3 Cam
Stage 3 LS7 Cylinder Heads with 2.200 Titanium intake valves and 1.61 stainless exhaust valves; Double valve springs good to .660 lift
Comp Pushrods
Complete Front Cover gasket set
Gates Belt
LS7 Crank Bolt
ARP Head Bolts
GM Head Gaskets
LS Valve cover gaskets
LS7 160* Thermostat
C6Z Mild to Wild Exhaust Control
Racing Oil Filter
Dyno Tuned
http://www.youtube.com/watch?v=y8VFZWxbEIE
**C6 Z06 Twisted Package** Call for pricing(supercharger choice effects pricing)
C6 Z06 Corvette Twisted Package:
-Procharger D1SC Supercharger System
-High flow injectors
-Dyno Tune
-Magnuson TVS 2300 Supercharger
-Raised cowl hood for C6 Corvette(color matched to vehicle)
-Dyno Tune
Edelbrock E-force 599 HP Complete Supercharger System for 2008-12 Corvette
-High Flow Injectors
-High Output Fuel Pump
-Dyno Tune
http://www.youtube.com/watch?v=j1iOpeYYfYE
http://www.youtube.com/watch?v=DpHLeLuPa8c
http://www.youtube.com/watch?v=66w50Vvri-k
**C6 Z06 Punisher 440ci Package**
http://www.youtube.com/watch?v=vltaiLDhtzA
C6 Slayer Package: Retail $6,999 Special $5,999
-Cold Air Induction Sysetm
-Stainless Steel 1 7/8 stainless steel headers with catted X-pipe
-MSD Spark Plug Wires
-NGK Spark Plugs
-160* Thermostat
-Underdrive Pulley Kit
-LMR Custom grind cam shaft kit
-All bolts/gaskets fluids included
-Custom Dyno Tune
http://www.youtube.com/watch?v=fmsIo...3&feature=plcp
C6 Reaper Package: Retail $9,999 Special $8,999
-Cold Air Induction System
-Stainless Steel 1 7/8 headers with catted X-pipe
-NGK Spark Plugs
-160* Thermostat
-LMR Custom Grind Cam Shaft
-Comp Pushrods
-LMR Stage III L92 Cylinder Heads
-All gaskets/bolts/fluids
-Custom Dyno Tune
http://www.youtube.com/watch?v=gE4tZGQ_Ynk
**C6 Twisted Package** Call for pricing(supercharger choice effects pricing)
C6 Corvette Twisted Package:
-Dyno Tune
-Dyno Tune
-Dyno Tune
http://www.youtube.com/watch?v=QeJWayie5fc
5th Gen Slayer Package: Retail $5,999 Special $4,999
LMR Cold Air Induction System
American Racing 1 7/8 Stainless Steel Headers
American Racing connection pipes with high flow cats
02 Extensions
NGK Spark Plugs
LS3 160* Thermostat
Modify Factory Exhaust
LSX Cam Kit
Front cover Gasket Set with crank bolt
Complete Installation
Motor Oil
Oil Filter
Shop Supplies
Dyno Tune
http://www.youtube.com/watch?v=Bsb-x0ZSdno
5th Gen REAPER Package: Retail $9,999 Special $8,999
American Racing 1 7/8 Stainless Steel Headers/Connection Pipes with high flow cats
02 Extensions
NGK Spark Plugs
LS3 160* Thermostat
LS3 Cam
Comp Pushrods
New GM L92 casting, 5 axis CNC machined, Fully assembled
Intake Flow Rate 360 CFM
Exhaust Flow Rate 245 CFM
ARP Head Bolts
GM Head Gaskets
Front Cover Gasket Set
Crank Bolt
Custom Dyno Tune
http://www.youtube.com/watch?v=rfyZ7QBTRF4
**5th Gen Twisted Package** Call for pricing(supercharger choice effects pricing)
5th gen Twisted Package:
-Dyno Tune
5th Gen Twisted Package:
-Dyno Tune
http://www.youtube.com/watch?v=oiX43bmldXk
http://www.youtube.com/watch?v=_fPIf1Uf8A0
http://www.youtube.com/watch?v=BzYBaXBsO6Q
We do have an enclosed transport that travels the country picking up and delivering vehicles. For more information please contact one of our sales staff at sales@latemodelracecraft.com steven@latemodelracecraft.com or are shop phone 713-466-9900. Offer only valid through the month of June. Must have deposit by June 30th.
02 Extensions
LS3 160* Thermostat
LS9 Crank Bolt
Lowering Bolt Kit
Coolant
Slayer C6Z Package:
02 Extensions
NGK Spark Plugs
C6Z3 Cam Package
Gates Belt
LS7 Crank Bolt
LS7 160* Thermostat
Racing Oil Filter
Shop Supplies
C6Z Reaper Package:
02 Extensions
NGK Spark Plugs
C6Z3 Cam
Comp Pushrods
Gates Belt
LS7 Crank Bolt
ARP Head Bolts
GM Head Gaskets
LS7 160* Thermostat
Racing Oil Filter
Dyno Tuned
-Dyno Tune
-Dyno Tune
-Dyno Tune
-NGK Spark Plugs
-160* Thermostat
-Custom Dyno Tune
-NGK Spark Plugs
-160* Thermostat
-Comp Pushrods
-Custom Dyno Tune
-Dyno Tune
-Dyno Tune
-Dyno Tune
02 Extensions
NGK Spark Plugs
LS3 160* Thermostat
LSX Cam Kit
Motor Oil
Oil Filter
Shop Supplies
Dyno Tune
02 Extensions
NGK Spark Plugs
LS3 160* Thermostat
LS3 Cam
Comp Pushrods
ARP Head Bolts
GM Head Gaskets
Crank Bolt
Custom Dyno Tune
-Dyno Tune
-Dyno Tune
you guys really are one of the best in the business. congratulations for all that you have accomplished in such a short time. and cant wait to see what you guys do in the future
Steve, LMR has been taking care of me for years now... I have three cars with/built by LMR and every one of them has exceeded expectations!
Bump for one of the best shops around!!
Congrats on the anniversary. You guys deff build some bad stuff. I am amazed everytime I see another one of your videos bc you guys keep raising the bar. Keep up the good work!
Thanks for the nice words guys and for all the Packages sold this month already!!! Please email or call our sales staff today to get in our schedule book because the days are running out on this SPECIAL.
Here are a couple examples from the past 2 weeks.
http://youtu.be/onMrJapKqNc
http://youtu.be/nuDGvxHdBVo
http://youtu.be/sz5UMzBjNGM
http://youtu.be/ff-39mnjlDg
http://youtu.be/txnjPw16sxQ
