How much power can this iron short block hold?
Seasond LQ9 bored .020 over, stock crank, Lunati Pro-Mod forged rods (6.125"), and JE forged pistons (-22cc dish). Should yeild ~8.2:1 compression with the 317 heads.
How much HP would this combo be "good for"?
Definantly. The heads will lift before you break the block.
Also yes. I would just run LS9 Headgaskets since they be cheap. Also seem to be doing well on a lot of motors.
Going to stick with the stock 317's for now and just put the ARP head studs and ls9 gaskets on it. I will realistically probably only push it to 20psi and I'm not even sure if the S475 will be able to keep up. At 13 psi i was trapping 115, at 15psi i was traping 118, and at 17psi it was going 120mph. I figure if I can put 20psi it should put me in the 122-125 range which is where I'd like to stay for a while. (1/8th mile of course).
