Need to plug a -10 AN oil return
Old 06-02-2012, 10:56 PM
evo462's Avatar
Default Need to plug a -10 AN oil return
I tapped the side of my oil pan with a -10 AN fitting for an oil return and it looks like the location that my turbo plumbing runs, I won't be able to get a fitting on it. I can probably do a timing cover return, but need to address the hole in my oil pan. Do they sell "caps" that I can put on this male -10 AN fitting that will reliably keep it sealed? Or am I gonna hve to go through the hassle of swapping out oil pans?
Old 06-02-2012, 11:25 PM
westtexasbuff's Avatar
http://www.summitracing.com/parts/EAR-992910ERL/
Or you can weld the hole.
Old 06-02-2012, 11:34 PM
evo462's Avatar
Originally Posted by westtexasbuff
I assume those seal as well as a drain plug would? I'd weld the hole, if I had a TIG welder. In fact, lots of things would be much more simple if I had a TIG welder.
Old 06-03-2012, 12:04 AM
gorr4's Avatar
yep a -10 cap is all u need.
it will be the same seal as having a line on it.
Old 06-03-2012, 07:55 AM
JAX04's Avatar
-10 cap on my oil pan. -8 caps on my fuel tank
Old 06-03-2012, 07:56 AM
evo462's Avatar
Thanks. The description on many of those caps talked about "keeping the engine clean while moving or storing it", which come to think of, is probably more common of a use....but just wanted to make sure.
Old 06-03-2012, 08:30 AM
Old Geezer's Avatar
Unless you tapped the pan for a straight/o'ring fitting, all you need is to remove the fitting and put a pipe plug, with some thread sealer on it, in the hole..
Quick Reply: Need to plug a -10 AN oil return
