Wastegate Mounting Position
I've been reading that directly in the exhaust flow path is best for mounting the wastegate and 45 degrees from it is good. I was thinkingif you come off of the collector with a 45 and then it bends another 45 is that alright to do or would it be the same as a 90 into the wg?
i always install mine on the outside of a bend if possible and straight or shallow angle on the actual pipe goin to the gate. out of the dozen plus kits ive built NONE have had creep this way
