stock cube cam help
stock cube cam help
ok im doing forged 346 ls6 intake 317 heads and 78mm front mount , trying to figure out which cam would be best , i was thinking of going with a ls6 or speed inc tu1 ,i have a255 pump and 60lbs injectors this is my first turbo car and i just want to make sure i build it right with what i can , anyother cam suggestions would be great thanks
I can't remember if it's the TU1 or TU2 I have but it's the one that's 225/225 from speed inc. awesome cam for a 346. My car with a large frame made 756/781 at 15psi with my old 80mm.
Still have the same cam in the same motor with a large frame on it now. Made 781/775 @ 9psi. All on 93 octain. Gonna push it as far as it will go
I run the tu1 cam in my car and like it. My build is very similar to yours so I don't think you'll be disappointed. Car is really responsive and spool is really quick.
68mm turbine(TC78) with .96AR. Stall is a 3600 circle-d multidisk, 3.73 rear and the car is full weight at about 3600lbs. The only issue I have is due to the small turbine wheel I choke a little up top, but this car has such a great midrange and spools so damn quick.
It wouldn't be my choice though for a bigger turbo, but with the small turbine you have, and an early evo opening you are able to spool your turbo very quickly.
That said I was actually asking the OP what his car weighs, stall speed and rear gear
Fbody you seem to know your stuff on reading a cam card. Maybe you can calm my nerves a little on this swap.
I'm running a 4.8L with magnum 76/67 .96 t4 at 21-22psi and 50 shot of nitrous with a ls6 cam. Truck pulls very strong to 6k then goes flat.
Would you trust this cam with back pressure i'm likely seeing with my setup? Looking for 3500-6500 power. I'm looking for an extra 50-75HP to push closer to 9's 1/4. I leave on a transbrake and 2-step usually at 3400, but can go higher.
I have the cam in hand, just be up in the air if this is a good move with this turbo.
Thanks for your input bud and any others who care to share their thoughts.
-Rob
