240sx crate LS1 ebay GT45 build thread... I'm probably going to kill myself.
This is my brother's car, but I'm the better fabricator so I'm doing most of the work on this car. Originally, this was an SR20DET swapped car that I made some ballin' exhaust manifold, downpipe, and chare pipe for so we could put an ebay GT35 turbo on. That setup worked surprisingly well, but my brother found an LS1 swap locally that he couldn't refuse. It was a total steal.
Specs:
Crate LS1, 0 miles
Rebuilt t-56, 0 miles on rebuild
new LS7 clutch, slave, CNC master and adapter for the s chassis, remote bleeder too
all new accessories except for the alternator
DAFT s chassis crossmember, trans mount, motor mounts
GTO oil pan
new aftermarket wiring harness and PCM
everything to plug it in, including a speedometer adjuster
every belt, hose, literally everything it needed to plug in and go
$5400!
The car:
1989 S13 coupe, silvia front end
Megan Racing coilovers
Q45 diff and 300ZX TT axles
Custom steel driveshaft
Wilwood 6 piston brakes up front, Z32 brakes out back
17x9 F 17x10.5 R, rolling on 315s out back. Gotta love how much tire you can fit under a little S13 with fender flares
Turbo stuff:
Ebay GT45 turbo
Flipped truck manifolds
emusa 38mm wastegate
dunno about the BOV yet
water to air intercooler setup
340lph fuel pump, vette filter/reg, 3/8" stainless hard line from the pump to the engine bay
And some pics of where we are at now.
Motor as received
The front end was rusting away, we put on a new core support, basically the whole nose of the car was replaced.
Friend helping out
Success!!!
Crate LS1, 0 miles
GTO oil pan
$5400!
The car:
Turbo stuff:
Ebay GT45 turbo
Motor as received
Friend helping out
Success!!!
Very nice.!
I'm using the Emusa wastegate on a stock lq4 with a ls9 cam and gt45 and the lowest boost I can drop it to is 9lbs. also I only left the soft spring in it. Just fyi. It works pretty good. I have the same bov too. Works like a charm.
Eh, too much of a pain to try to host them elsewhere.
I got the hot side back in the car for downpipe mockup. She is sitting pretty. The downpipe shouldn't be too difficult to rig up.
I think this is where the water to air core is going to sit. I'll need to mount it further recessed in the fender for hood clearance, but that shouldn't be that huge of a deal.
How much power you making
Attachment 359240
Attachment 359239
Attachment 359238
Attachment 359236
Attachment 359237
Attachment 359240
Attachment 359239
Attachment 359238
Attachment 359236
Attachment 359237
Here is the wastegate all welded up except for the last part. I'm not sure if I'm going to put another vband there, or a small flex joint, or just weld it up. Any ideas?
I don't see how that's an issue, the whole point of the wastegate is to bypass some of the pressure and flow around the turbo, and that's exactly what it's doing, even if there is some turbulence. I don't think it'll matter much.
