Spraying Meth before or After the IAT sensor?
Old 06-14-2012, 03:08 PM
SUPERMAN_00TA's Avatar
Default Spraying Meth before or After the IAT sensor?
I need oppinions on where to spray meth. I heard people spaying before and after the IAT sensor. Where do you recomend?
Old 06-14-2012, 03:22 PM
Twitch1's Avatar
If you spray before the IAT you could tune it to pull timing if your meth stopped flowing and IATs spiked.
Old 06-14-2012, 03:34 PM
WheelsUp84z's Avatar
Always spray before. That way in the event the tank runs dry or the pump fails, the IAT spark correction will save your motor when the IATs rise.
Old 06-15-2012, 10:27 AM
Thanks guys!
Old 06-15-2012, 10:51 AM
a4ls2goat's Avatar
this is how i have mine setup with 2 nozzles
Old 06-15-2012, 11:02 AM
02LS1ram's Avatar
I was just about to post this question! Not to hijack but how far away should the nozzle be. Wont that soak the IAT with the nozzle to close and give you false reading
Old 06-15-2012, 11:06 AM
a4ls2goat's Avatar
theirs no way itll "soak" the sensor since the air coming in is hot as it is, and if you have a quality nozzle itll be injected as a very fine mist.
Old 06-15-2012, 12:08 PM
masnart2000's Avatar
Yeah, it would be no fair to leave your poor IAT out. Always remember this:
IAT's like to smoke meth too!
Old 06-15-2012, 01:25 PM
KILLER-LS1's Avatar
i put mine about 6" before the IAT so it would have time to atomize better before hitting the sensor. Working great so far
Old 06-15-2012, 02:17 PM
willizm's Avatar
I think the rule of thumb is 12" from the throttle body for proper atomization and it should be before the iat sensor. I know that's how I'd want it so that I can see how much my iat's drop when meth is spraying.
Quick Reply: Spraying Meth before or After the IAT sensor?
