KR and running e85
Old 06-17-2012, 11:11 PM
03LQ9's Avatar
Default KR and running e85
Hi guys, I'm getting knock retard blips running a tad over 5psi on my 6.0l LQ9, the timing is at 15* when its at 5 psi around 3000 rpm. The turbo is a ebay gt45 and with no intercooler the intake temps are around 120F after a 0-70mph pull. Does this sound like false knock ? e85 should handle this no problem I would think? I would like to get 10 psi and keep the 15* of timing.
Thanks!
Old 06-17-2012, 11:30 PM
a4ls2goat's Avatar
sounds like you need a intercooler if you wana keep those pistons in 1 piece
Old 06-18-2012, 07:10 AM
LS1Tech Sponsor
hellbents10's Avatar
Yes it does sound like false knock, you are not asking to much of that fuel.
Old 06-18-2012, 10:16 AM
oange ss's Avatar
I'm running 17*@12-14lbs with a TC78 and E85, IAT 112-118 *F, no knock
Old 06-18-2012, 04:03 PM
Ryans99ls1's Avatar
im at 18-19* 12lbs spike settling 9 by 6000rpm. not sure on intake temps and im on stock shortblock ls1. you should be able to get more out that lq4
Old 06-18-2012, 04:51 PM
03LQ9's Avatar
My buddy is running 5.5 psi in his 5.3 that has a small supercharger with IAT's in the 190+ range and 20* of timing and 92 octane it has no KR. Thats why this KR showing up on mine is kind of weird to me ?
Old 06-19-2012, 04:20 AM
skinnies's Avatar
Sounds like false knock or another issue going on, check the plugs to make sure you don't have some other issue.
Old 06-19-2012, 11:30 AM
03LQ9's Avatar
I'm running the AC delco plug thats equal to the autolite 103 which I believe is stock heat range ? I was told they were good up to around 500whp and e85. I wonder if that is an issue ? I pulled the no. 7 plug yesterday and it just looked like a new plug, no coloring, there is around 600 miles on it. Sometimes the KR starts at 30% throttle with no boost then tappers off throughout the run after boost hits full on.
Old 06-19-2012, 11:18 PM
03LQ9's Avatar
I went and go e85 from a diff station today and it still shows KR so i commanded 10* of timing and the KR got even worse.
