Vortech v2 sq to v2 t trim
Old 06-20-2012, 09:58 PM
Lil'Felt's Avatar
Default Vortech v2 sq to v2 t trim
So I had a v2 sq unit that came with my car n it spun a bearing so I purchased a v2 t trim off of a guy that was rebuilt with new casing and interals etc etc has all the paperwork for it. I pop off my old one to mock it up with the new one and they look totally different...from the angle the outlet is to the mounting points. I even called vortech to see if it would fit n the guy said it would minus the inlet...do what do I do now? I need help guys and fast I'm very frustrated and my car is down.
Old 06-21-2012, 01:14 AM
qwiketz's Avatar
loosen the volute and reclock the volute. Once you loosen the volute (the outside outlet piece, you can spin it to get it clocked correctly.
Old 06-21-2012, 08:03 AM
Lil'Felt's Avatar
But then the outlet is still on the wrong side and even if I did get some piping to make it work it wont clear a couple of other things..
Old 06-21-2012, 09:35 AM
qwiketz's Avatar
did you confirm that they where the same direction rotation prior to buying them? What is your application and what was the new one off of?
Is it a straight discharge unit? You can rotate the volute a full 360 to whereever you need it to be. You can also rotate the actual blower part by changing the drain plug and feed plug.
Old 06-21-2012, 09:47 AM
Lil'Felt's Avatar
I called vortech prior to buying and even before I went to take my car apart n the guy said that would be good to go.
Old 06-21-2012, 10:58 AM
qwiketz's Avatar
don't know what to say... to my knowledge they're interchangeable(v1,v2,v7). The only ones that aren't to my knowledge are the v4 and v27's(different bolt patterns).
If you confirmed that it'll work from vortech then you have to play with the roation of the volute or the actual blower as I mentioned. You're going to have to play with it and get it to work; there's not anything I can say to instantly solve your problem.
Old 06-21-2012, 12:20 PM
Lil'Felt's Avatar
do you think id be able to just take the head off, the snail looking part and interchange those? or will that not work? if thats the case id be pretty good...or will i be able to mack a new bracket to push it over some so my piping to my after cooler will still work?
Old 06-21-2012, 12:21 PM
Lil'Felt's Avatar
i think i am going to fab up some new brackets to make it work..
Old 06-21-2012, 02:31 PM
Lil'Felt's Avatar
Anyway that would work?
Old 06-16-2014, 02:30 PM
ticktickticktick's Avatar
man this post is old and i am sure its been resolved but sounds like you are dealing with a cw/ccw issue. i got the same problem basically. i need a ccw volute and impeller, because the blower spins *** backwards now and the discharge is 180° from where i thought it would be.
Quick Reply: Vortech v2 sq to v2 t trim
