spec some turbos
spec some turbos
Id like to be around 1000hp with my 396 LTx Ive got a LT4 block Dart Pro 1 200cc heads Im gettin those & my LT1 intake ported. My crank is a Callies Dragonslayer 3.875 , Rods are 5.85 Howards Billet, Pistons will be Diamond or JE, Prolly E85 160lb injectors. & a built 4L80E. Its goin in my 95 Ram Air Trans Am What I need to know is What single turbo will get me there & specs ,A/R etc... Or what set of Twin Turbos & specs, What size waste gates & BOV??? I know I will upgrade the fuel system with twin walbro 340lph or 255lph Im a Newbe at this so dont rip me to bad lol I really like the sound of Its a twin turbo 396 LTx with 1000hp
For a dd id go comp turbo oilless t3 6262 .82
All out hp comp oilless t4 6765 ett .68
If u have space and $ u could add a qsv and go up slightly on the ar's
As for the comps if u have the $ they are worth every penny
I just saw that they added entry level turbos with billet compressors for a very good price....
httquick spool valve...$$$ we use them on a a few cars work excellent if ur willing to part with the $
http://www.supraforums.com/forum/sho...uctions-Thread
For 1000hp with those cubes you would need an 80mm minimum. As you will need somewhere in the 100lbs/min range at an efficient level.
As for twins, a set of 6265 units from Tnetics or PTE would suit that build easily.
Yeah Twin Turbo & a Thousand horsepower just has a nice ring to it LoL Problem is Ask 8 different shops or turbo guys & ya get 8 different answers LoL Ive been told anywhere from 62mm to 70mm So kinda split the difference & go twin 67s or what Get .9x A/R
