RedRocket's 01 Z28 build - S480, Tick Cam, SBE LQ4, 4L80E, E85
What's everyone's thoughts on a blanket? My turbo sits VERY close to the water pump and I believe that a blanket would rub on snout. Any suggestions, thoughts, or comments?
Car should be running in the next couple of weeks. Installing the trans this weekend and starting the wiring. Not sure what to do about the radiator hoses either. Might buy some different ones and do a little trial and error unless someone has anything else in mind.
during mock up, but you see how close it is, mayyybe a 1/2 inch
Some more progress made Friday and Saturday.
Transmission in using the BMR crossmember.
Madman dipstick.
Trans cooler.
Fans.
Will hopefully get some more work done today. Try to get the radiator hoses figured out, might start some wiring too. Hopefully running in a week or so.
Madman dipstick.
Trans cooler.
Fans.
Swap the water pump pulley to one from either a ls2 or ls3. Those pullies are smaller and will give you more clearance. You can also just make your own radiator hoses by using some metal pipe and fit some 90 degree radiator hose ends. Those 80lb injectors are pretty small for e85. What kind of fuels pump(s) are you using? I may have missed that.
A little update. Got the wiring harness in and all hooked up for the most part. Fuel pumps are wired up as well. Need to source the parts for the ABS delete, install the gauges, put the interior back together, get fluids, and run vacuum lines. Should be fired up this weekend if all goes as planned.
I do have a question about the vacuum lines. I bought a vacuum block and am wondering what is the best place to source the vacuum for the block? Best place at the manifold? Which port?
#33
Which look should I go for?
TT2's are played out I know. Black rims on red are especially played out. It's what I have to work with though. These rims came as a second set with the car.
Berger panel is black as well. Z28 emblems will be coming off the fenders too.
Will hopefully have a start up video this weekend.
#34
I'd go with the full polished, black or gunmetal wheels are really being played out these days. It seems like all new cars & trucks could now be ordered with black/gunmetal wheels from the dealership. Don't get me wrong, I still like black wheels, but it's getting to be way too common on the streets, somebody at my work just bought a brand new black 4dr.Honda Accord with factory gunmetal rims.
