RedRocket's 01 Z28 build - S480, Tick Cam, SBE LQ4, 4L80E, E85
Old 04-15-2014, 12:10 PM
  #221
RedRocketZ28's Avatar
Originally Posted by 99Z28LS1
Do those gates work good? I know they're cheap, but if the work good, it could save us other guys A LOT of money by not paying for the brand name ones.
Not sure yet. I know Sarg on here uses them on his build. I have seen a few other guys use them as well. I should know shortly.
Old 04-16-2014, 07:44 AM
  #222
Started on the downpipe last night and it's about done. Will finish that this week and get everything put back in place. Got the Contour fans completely trimmed. Need to have a buddy bend up a shroud for it sometime. Still should be on track for some seat time with it this weekend if the driveshaft shows up Friday.
Old 04-16-2014, 07:53 AM
  #223
Phish806's Avatar
Are you eventually going to put that thing on a cutout, or just run it as is?
Old 04-16-2014, 08:14 AM
  #224
STEEPSS's Avatar
Posting on the line eh?
Old 04-16-2014, 08:51 AM
  #225
Yeah, eventually. I will try to do something like Jordan has at some point. Didn't want to mess with it right now.
Yeah. I figured I would take the pics and put them on the line for everyone to see.
Old 04-17-2014, 07:47 AM
  #226
STEEPSS's Avatar
Online.
Old 04-17-2014, 07:49 AM
  #227
JAX04's Avatar
Online.
Why dont we just settle this over a game of Horsh
Old 04-17-2014, 08:17 AM
  #228
Online.
Dude, I am just taking the photos and instantaneously putting them on the line for others to see.
Done. Let's do it.
Old 04-17-2014, 08:18 AM
  #229
JAX04's Avatar
Lol, im guessing you dont have Sonic where your at?
Old 04-17-2014, 08:20 AM
  #230
JAX04's Avatar
Old 04-17-2014, 08:36 AM
  #231
STEEPSS's Avatar
Online. You're taking photos and putting them ONLINE.
We do. Des Moines has a way of killing them though. I think there's only 2 or 3 left in the whole metro area. Def. not a hit like in other areas though.
Old 04-17-2014, 05:30 PM
  #232
99Z28LS1's Avatar
I think Denmah uses them on his builds, and lord knows he'll put them through their paces MUCH more than we ever will.
Old 04-17-2014, 05:54 PM
  #233
Sarg's Avatar
The EMusa gates have worked well so far. Only two issues thus far is the 15 psi spring is producing 18 psi and the sealing of the copper crush gaskets around the banjo bolts on the side of the wastegate is not ideal. I plan to remedy this with push on nylon air lines and NPT fittings in the side of the gates.
Old 04-17-2014, 06:43 PM
  #234
hilio's Avatar
Where did you get the ring around the exhaust ?
Old 04-18-2014, 12:30 AM
  #235
Funkster's Avatar
Monkey Fabrication.
Old 04-18-2014, 08:03 AM
  #236
Yep, that's what I used on mine. Made routing the lines much easier too.
Monkey Fab Garage, like Funkster said.
Originally Posted by Funkster
Monkey Fabrication.
Yep.
Downpipe.
How should I trim this?
Looking through the passenger headlight area.
Hopefully will be driving it tonight a bit.
Old 04-21-2014, 08:09 AM
  #237
How it looks as of now. Need to coat/paint the radiator shroud eventually. Install the ABS delete kit and clean a few other things up.
And...it rolls out!
I think the wastegates are plumbed wrong (at least I hope). It's boosting past the 7 lb. springs in them, lol. Either that, or I have the wrong springs in. Either way, I will get it figured out. The thing absolutely rips though. The Tick cam has way more out of boost snap than the TU1 did. It also comes into boost QUICK. I am definitely pleased with how well it's running so far. I have put over 70 trouble free miles on it so far. Tune isn't too far off from what I can tell. Need to get the man MaxxMitchell to tweak a few things, but overall it seems good. It was pretty rich with the old setup. It would have been in the mid 10's AFR on the pull above for sure. Will try to get some more things ironed out this week and hopefully flog on it a bit this coming weekend.
Old 04-21-2014, 09:52 AM
  #238
sbcgenII's Avatar
How does the spool compare to the 76/75?
Old 04-21-2014, 10:16 AM
  #239
Honestly it doesn't "feel" much different and comes on around the same RPM from what I can tell. The 2 1/4" piping probably helps quite a bit there. It's not as violent as the 7875 was. It is more of a gradual feel coming into boost which is nice for street use.
Old 04-21-2014, 09:48 PM
  #240
sbcgenII's Avatar
Thanks for the intel. This has been a great thread watching your car evolve.
Quick Reply: RedRocket's 01 Z28 build - S480, Tick Cam, SBE LQ4, 4L80E, E85
