on3 44mm waste gate
one thing with the chinese gates is id make sure and pull it apart and fully inspect it to make sure its good to go.i had to do a little clean up on my tial knock off but its working flawless
I have one. I took it all apart and cleaned it. Lots of dirt in it. Text me for pics of the internals. There are some things I did to make it better also. Pm me for my number
or just get a 130~ dollar 60mm vband from VSracing
ive used about 6 of the cheapest chinese gates viren can get me and ive never had a problem to date.
2psi-22psi no problem comes with a few springs you can mix and match too
Pretty sure with all the cheaper wastegates is keeping steady boost at lower levels and making sure there is not spiking. Materials will be cheaper than good name brands so wont last as long. Also any material breaks from heat cycling theres only one place for it to go. Rather spend few hundred or couple hundred more to ensure your turbos health.
no spikes, creeps, bleeps or sweeps
either way they work great
