E85 guys come in...
Old 07-05-2012, 04:45 PM
13 Second Truck Club
LS1FREEK's Avatar
Default E85 guys come in...
Well my brother is taking his truck to the track Saturady, and while playing around on the street we've noticed that with E85 the truck loves a lot of timing, but I'm not sure how much is safe? I've pushed as much as 18*@12#s, 16*@14#s and 14*@16#s... We wanna run more but we're not sure where the limit is? We haven't gotten any knock at all yet.. also, at what AFR are you guys makin the most power?
His truck has a '99 4.8L w/706 heads, ARP studs MLS head gaskets, Isky triple 12 cam and a 76mm front mount.
Old 07-05-2012, 05:05 PM
willizm's Avatar
I'd have to check my AFR on e85, but my car is tuned to about 20* of timing on e85(17.5psi) and about 15-16* on 93 octane(12.5psi). e85 is very knock resistant and my tuner said he could push more safely, but it gets to a point of diminishing returns.
Old 07-05-2012, 05:49 PM
MJD
MJD's Avatar
My AFR averages at about 11.7, timing is set at 22* IIRC. I wasn't getting any benefit from running more timing. When I was NA I ran 28*. I run 6.5 psi on my setup.
Old 07-05-2012, 05:58 PM
Adam Connell's Avatar
Throw more boost at it... I run 22lbs in my DD 87 Grand National and even in this 100+ deg heat it's happy as a clam.
Old 07-05-2012, 06:05 PM
Old Geezer's Avatar
What are the plugs telling you??
Old 07-05-2012, 06:14 PM
AlterEgo's Avatar
Your bro has a 99 E85 motor? I didnt know E85 was out that long.. Did he convert it over or something?
How does that cam work out for you?? Sound good? (got a video clip???)
what injectors are you running?? (and what is the max boost you run with them??)
Old 07-05-2012, 06:31 PM
ls2foryou's Avatar
If you tune for e85 It does not matter.... lt1 s can run on e85
Old 07-05-2012, 06:36 PM
LS1NOVA's Avatar
18* at 19psi with 11.5afr.
Old 07-05-2012, 06:50 PM
AlterEgo's Avatar
Sorry nova but I don't kno exactly what that means??
Old 07-05-2012, 06:51 PM
AlterEgo's Avatar
What size injectors are you running?? And how is that cam working out for you?
Old 07-05-2012, 07:17 PM
03LQ9's Avatar
What IAT's are you guys at ?
Old 07-05-2012, 07:55 PM
LS1FREEK's Avatar
Ok, are any of you guys running stock bottom ends? I guess I should have stated that in my question, I'm curious what guys are running without hurting stock bottom ends.
Old 07-05-2012, 08:08 PM
boss79z's Avatar
Just got mine tuned, and not quite done.
Stock bottom end ls1, 47xxx, ls6 cam, Kytp kit with a pt 7675, e85
We are having boost creep problems with the pw46 wastegate, so haven't pulled it to high yet. I live in San Antonio, so with the heat it made 602 rwhp, 570 tq with 12* timing, 12.5 lbs, pulled to 5800.
In a month or so, we will be adding a 50mm wastegate from josh at kytp, and extending the exhaust out the back. The plan is to bring it down to 10lbs, run 14-16*, and pull it to 6200. We think it wil be close to 650 rwhp.
Old 07-05-2012, 10:20 PM
oange ss's Avatar
Glad you brought this up. I'm running 18*@13-ish psi, stock bottom end LS1. Would like some timing advice too.
Old 07-06-2012, 09:37 AM
AlterEgo's Avatar
Ahhhhhh!! I get it after reading a couple of times!! "18*" 18 degrees of advanced timing!!
Old 07-06-2012, 09:38 AM
AlterEgo's Avatar
not familiar with all of the shortcut wording just yet but I am learning them quickly!
Old 07-06-2012, 10:13 AM
1BADAZZSS's Avatar
Friend is running 30* on 20# on a stock long block 5.3 with twins. Wont grenade, he's tried lol
Old 07-06-2012, 10:37 AM
AlterEgo's Avatar
now thats what I wanna hear!!! stock long block.. what about intake, fuel pump and injectors for those twins??? Im looking to do the same with my 4.8...
Old 07-06-2012, 11:21 AM
1BADAZZSS's Avatar
I believe pro flow xt, dual pumps, and 80#. Oh yea and NO INTERCOOLER!
Old 07-06-2012, 01:55 PM
offaxis's Avatar
What are your iats with no intercooler? E85 is real nice ( I run it also ) but I would either run meth or intercooler or both..I think you are leaving power on the table not cooling that air down. 30 degs of timing on 20 #`s in the summer heat he is the luckest guy alive. A 5.3 is hard to break item.
Quick Reply: E85 guys come in...
