Best twins for a LSX 427?
Old 07-09-2012, 06:37 PM
6togo's Avatar
Default Best twins for a LSX 427?
Think i decided to go twins due to size and need to know what pair will work best. The build is a forged LSX 427 fully ported ,4l80 trans,9" rear mostly street but some track time looking for 1000+ rwhp with quick spool time and maybe some room to grow! Any help would be appreciated plus i need to buy the turbos,wastegates,and bov's so vendors jump on!
Old 07-09-2012, 06:46 PM
Dynospeed's Avatar
precision 67's. With decent compression, heads, cam, and converter you can even go a little larger. We did a lsx 427, 10:1, prc ls7 heads, m6 corvette that spooled twin t4 76's pretty well.
Old 07-09-2012, 06:55 PM
qqwqeqwrqwqtq's Avatar
Would you rather have very fast response or would you rather sacrifice some response for more power potential?
For a 1000rwhp 427, twin 35R's would be very fun and have almost no perceptible lag. That's how I prefer it, to get pushed back in the seat -as- you are rolling onto the throttle, not after.
6766's will make a good bit more power but aren't going to have the part throttle hit the 35's have.
Old 07-09-2012, 07:40 PM
Z06_Fan's Avatar
How about in the middle of the road with a 6466 ?
I'd love to see some combinations running this turbo.
Old 07-09-2012, 08:42 PM
6togo's Avatar
I would really like a happy med. but if i had to favor a side the quicker responce would win! I know a few guys starting to play with single 6466's on the turbo buicks with nice results!
Old 07-09-2012, 08:57 PM
Toxic-Evo's Avatar
if you talk with PTE, they say the 6766 is better for most V8 applications.
the 6466 is a great turbo for HIGH rpm motors. like 2.0L evos. lol.
Old 07-09-2012, 09:10 PM
gnx7's Avatar
I've been in a FordGT with twin GT35R's and it spooled up too fast. 1st and 2nd gear were pretty much unuseable.... that was even on low boost. They spooled instantly literally.
Old 07-09-2012, 09:21 PM
blackmagicturbo's Avatar
and thats a 5.4 , could you imagine on a 7.0 ? i would be more concerned about back pressure with the 35s ,427 alone has alot of power and the turbos is just an added bonus
Old 07-09-2012, 09:33 PM
ws602's Avatar
What about the precisions 7675.
Old 07-09-2012, 09:48 PM
Coal Mining Director
onfire's Avatar
X2. For a primarily street car, 427ci, stock weight, hard to beat the GT3582R, especially the new GTX....At 3900lbs and the Speed Inc kit with GT35's I could pop both bulbs on, hit the transbrake at 3000 rpm (could have footbraked it) and pop off a 1.35 sixty and 9.2 at 146mph at 18psi....more left in it back then.
Old 07-09-2012, 10:11 PM
I8UR4RD's Avatar
yeah 67's, but im not so sure about the precision. i am not one to read a bad review or two.....but here lately........
Old 07-09-2012, 10:17 PM
6togo's Avatar
Yea i have seen allot of bad press on precision lately so i may stay away from them. Running to small a turbo/s was a big concern due to back pressure and i dont want it to be so touchy from instant spool its not driveable on the street!
Old 07-09-2012, 11:32 PM
blackonblacksls's Avatar
I raced a 3.0 liter supra that had a 6766 in it. In my 560rwhp NA camaro. And it had no lag. It came out harder than my car did. I wouldn't be worried about lag with two of them on 7 liters.
Old 07-10-2012, 12:05 AM
onfire how long did you run those turbos for ? and any effects on the motor or turbos ? sounds like a peppy setup , i know 35s are good for alot of power ,, and the .82 ar is not too small
Old 07-10-2012, 10:09 AM
onfire's Avatar
You could run that set-up for years. I am bad to change combos so I never got close to the limit of those turbos...18psi and 4 bolt heads and never a problem.
Old 07-10-2012, 10:57 AM
LS1TECH Sponsor
DrTurbo's Avatar
We have several customers running similar setups. The Tnetics 6665's have been used quite a bit and also the GTX3582's. Both turbos make the HP you want no problem. Prices are quite a bit different though, but nonetheless both are great units. Both are very compact and offer tons of options for customizing to your setup.
Old 07-10-2012, 02:05 PM
Tiago's Avatar
hell I run the GT35R's on a 522 CI motor and they spool awesome, tons of fun to drive, and still makes 1200 rw.
On the other hand, I have 76s on my 427, and although laggier, the TH400 makes it managable.
Old 07-10-2012, 02:09 PM
LS1NOVA's Avatar
Id go twin 76's if it was mine. I work on a car with a 427 with twin PT6765's and there is virtually no lag.
Old 07-10-2012, 05:46 PM
6togo's Avatar
Seems the recommend twins are 6665's or 6766's with a .81 AR and a few saying go 76's. Now i need to firgure out to do cast, billet, JB or BB?
Old 07-10-2012, 06:13 PM
6togo's Avatar
Sounded pretty sick! What AR are they and how much power you making at what boost?
Quick Reply: Best twins for a LSX 427?
