Is a 212/218 Low Lift cam to big for a E85 turbo 4.8L?
Old 07-12-2012, 01:28 PM
AlterEgo's Avatar
Default Is a 212/218 Low Lift cam to big for a E85 turbo 4.8L?
I found a deal on the truck low lift cam and I'm wondering if this is too much cam for a Turbo 4.8 running E85??
Would I have to get new push rods or LS6 springs with it??
My current plan is a single turbo (twins later on), 4.8L, ls2 intake, 92mm tb, stock heads (799 heads later on)..
I also need help / sizing for injector and waterpump with ls2 intake...
Old 07-12-2012, 02:19 PM
831jd's Avatar
What are your horsepower goals
Old 07-12-2012, 02:48 PM
AlterEgo's Avatar
I dont think I have a goal... But if I had to say, it would be about 700 to the wheels.... I think that is possible with a 76MM.... (I know a lot of guys with high horse power and I would like to race a couple of them, just to "shut them up" if you know what I mean...
Old 07-12-2012, 03:43 PM
LS1Tech Sponsor
hellbents10's Avatar
I think the cam would work pretty well, and I would run it if it was mine.
Old 07-12-2012, 08:41 PM
Fbodyjunkie06's Avatar
I also think it would work well depending on the lsa? I'm gonna guess it's a 114lsa being a truck cam.
I'd install it at 112 icl and have at it.
Old 07-12-2012, 08:51 PM
AlterEgo's Avatar
^^^ Yep!! Exactly 114 lsa.... So I'm guessing you also believe it will work great with what I am going to do????
Old 07-12-2012, 09:35 PM
9 Second Truck Club
stock48's Avatar
X2 I agree with above. Id put a little more spring on it tho.
Old 07-12-2012, 09:44 PM
AlterEgo's Avatar
Do u mean the ls6 yellow valve springs??
Old 07-12-2012, 09:45 PM
AlterEgo's Avatar
Wat about push rods?? Or anything else?? Would I have to swap anything else to run this cam and yellow ls6 springs??
Old 07-12-2012, 09:49 PM
9 Second Truck Club
stock48's Avatar
I would run a little stiffer spring than the yellow's with boost. Id go with the Isky 165A's, pac 1218's, or the comp single. Although a good set of pushrods wouldn't be a bad idea I run stock pushrods with more lift and same springs. If using ls7 lifters you might need a little shorter than stock length pushrod.
Old 07-12-2012, 10:15 PM
Most Hated's Avatar
i would install dual spring with boost u never know might get valve float and not even know it
Old 07-13-2012, 10:31 AM
AlterEgo's Avatar
Dual springs like this part#: Prc-199-675
Old 07-13-2012, 10:01 PM
9 Second Truck Club
stock48's Avatar
If you run the dual springs I would upgrade the pushrods.
Old 07-14-2012, 12:40 AM
Comp 918's will be fine as stock48 said.
Get NGK 3346 part number for plugs also.
Old 07-14-2012, 12:51 PM
AlterEgo's Avatar
Hey stock 48 and junkie, I read something about the Comp 918's were bad with breaking or going bad at one time or another... I can get the duals for $100. Only used for 4 months in a daily driver, not a track car. Im kind of iffy about the comp 918's because of that issue.
With my 212/218 low lift cam, what push rods would you recommend? I had not planned on changing lifters out, as you mentioned the LS7 lifters... But would that be a good idea with this cam?
(In possession: 4.8L, 706 heads, LS2 intake, 92MM TB, 212/218 low lift cam (but should have gone bigger),
(Planning on getting: 76MM turbo, with intercooler, maybe 799 in the distant future. I hear LS9 head gaskets thrown around a lot.. why is that, what is so special about them?)
700-800 Streetable weekend car is my goal.
Old 07-14-2012, 12:52 PM
AlterEgo's Avatar
and as for those NGK3346 spark plugs, are they good plugs in general or good for my application??
Old 07-14-2012, 12:53 PM
Yes use the 3346 plugs.
They are more commonly known as BR7EFS.
That was an issue that I'm pretty sure they addressed. You could use a PAC 1518 spring if you wanted, but as stock said if you use the stiffer duals you'll want to upgrade the PR's.
LS9 gaskets were designed from GM to withstand boost from the ZR1. They are a superior gasket for stock applications when it comes to forced induction.
Quick Reply: Is a 212/218 Low Lift cam to big for a E85 turbo 4.8L?
