Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
Old 02-11-2015, 10:43 PM
  #241
Boostedhatch's Avatar
Just completely read this thread awesome build even thru the fire you kept on. Question why not step up to the tr6060 Trans?
Old 02-13-2015, 09:46 AM
  #242
Ryans99ls1's Avatar
Can you post a few more pic of your downpipe routing? Ive been tossing around the idea of twins for awhile and that is EXACTLY how i wanted to run mine! Never seen it done before, on a 4th gen at least. nice work!!
Old 02-13-2015, 10:17 AM
  #243
LS1NOVA's Avatar
I will snap some pics the next later today. Basically dp's go around the front frame rails, under the sway bar, and down the sides of the block. 20minute cam swaps?
Old 02-14-2015, 09:25 AM
  #244
LS1NOVA's Avatar
Old 02-14-2015, 09:48 AM
  #245
Sarg's Avatar
That really is some nice work on the exhaust routing.
Old 02-14-2015, 06:40 PM
  #246
Lsx Fayz's Avatar
Work of art man cant wait to see the results
Old 03-25-2015, 08:58 AM
  #247
sbdgbody's Avatar
looking good
Old 06-03-2015, 03:29 PM
  #248
BanditDave's Avatar
Three months of waiting and nothing!?!!?! Uncool.....
Old 06-03-2015, 08:46 PM
  #249
transam69230's Avatar
It is done, and dyno'ed on 11lbs. Had some issues on the dyno. He's getting married this weekend so I wouldn't expect an update soon.
Old 06-05-2015, 05:06 AM
  #250
BanditDave's Avatar
Nice! Congrats to him! I'll assume the car will be up for sale soon then since he's getting hitched? Lol totally kidding!
Great to hear it's up and running!
Old 06-23-2015, 12:55 PM
  #251
Jakson's Avatar
Thanks! She is well aware that the car isn't going anywhere .
But yes as mentioned, the car is finally together and running. Just before I went to the dyno session I didn't have many miles on the setup, so I went out for a drive to do some boost pulls and a wastegate stuck open on me (Emusa 38s). So we took them off and cleaned them out and inspected them and put them back on. It was the same story, they were both sticking open, shut and everything in between. We decided to run it with shop air holding them open just to see what it would do, boost was creeping upto 16psi at high RPM. Luckily the shop (MAP) we were dynoing at ,had some Turbosmart Compgate 40s in stock that I picked up and bolted on. Of course it was late in the day by this point, so we only got some wastegate spring pressure only pulls in. The gates are still too small, and boost was creeping up, so we didn't bother hooking up the holley boost control yet.
At 11psi it was making 783rwhp with 14.5 degrees of timing. 1 degree of timing picked it up 65rwhp at that point. We were pulling to 8500rpm, she sounds mean! By then it was the end of the day at the dyno, so that's all the numbers I have for now. It was ready to drive to the wedding anyway!
I changed the springs out this past weekend and turned it upto 20psi, it finally feels kinda fast now! I will get some more numbers and videos later on, and hopefully get to the track this fall with it, a few bugs with the rest of the car to work out in the mean time.
Old 06-23-2015, 01:58 PM
  #252
IronBlocked's Avatar
20psi to 8500 should put you well over 1000!!!, groundbreaking build as far as rpms go, you don't see many v8 builds even built bottom ends go beyond 65-7000
Old 06-24-2015, 01:27 AM
  #253
TA63's Avatar
Great build Jakson! Any chance we can see the NA dyno sheet? Im assembling parts to do a similar build.
Old 06-24-2015, 08:44 AM
  #254
5FOX3's Avatar
Badass!!! im right in st.paul. I want a ride! haha
Old 06-25-2015, 11:42 AM
  #255
Jakson's Avatar
Thanks!
This is the only dyno graph I have online, sorry for the quality, but the red/blue is the N/A engine dyno of the current engine setup. The lighter green/yellow lines is an overlay of the old low compression/stock heads 332" with an LS3 intake manifold.
Old 06-25-2015, 12:56 PM
  #256
Rise of the Phoenix's Avatar
Too much goodness in this thread. Congrats on the car, and on getting hitched. I really like the way you routed the downpipes.
Old 06-25-2015, 09:13 PM
  #257
coltboostin's Avatar
Love it! Crazy this started 3 years ago....your a patient man!
Excited to see how it does at the track. Porps on doing it different, and pushing the limits. Cool to see a street LSx revving past 8k
Old 06-26-2015, 02:11 AM
  #258
TA63's Avatar
Man that thing rips hard even in NA form! Performs better down low than I initially thought it would.
Old 06-26-2015, 11:50 AM
  #259
3pedals's Avatar
What intake on it now?
Old 06-26-2015, 12:30 PM
  #260
Jakson's Avatar
Still running the short runner sheetmetal LS3 intake, fixed it up after blowing it apart on the last setup.
Quick Reply: Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
