Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
#82
Thanks everyone! Getting pretty excited to see how it does. Dyno day with the turbo is scheduled for November 16th. Got my billet rails, hose and fittings here now. So I have to make the lines for the fuel rails, and then some oil lines for the turbo. Ordered an LS1 to LS3 MAP extension for my LS9 3 bar map, along with a 2 step from lingenfelter yesterday. Also ordered the comp rocker trunion upgrade finally. Getting closer to making some big power!
#84
The most the dyno has seen is a 900 some HP nitrous LT1 I believe. Myron is excited to see it run for sure, he was impressed with the NA HP numbers from the little 332.
#94
did you have to get the rotating assembly re-balanced to use the 4.8 crank or did you just put it in and all the cranks are balanced the same?
been thinking of putting a 5.3 crank in my 6.0 since my 6.0 is a 2000 and has the longer crank in it that i cant use with my t56
#97
As far as the dyno situation, the engine is on the dyno again and running with the turbo setup. We had a different engine that was on the dyno until the last minute, so that pushed everything back as far as getting my engine on and ready to go. Then there was a few issues that came up, and we just ran out of time to get it running well before the tuner had to leave yesterday. We will be working on it again on Monday.
#98
Engine dyno results finally. 1092HP/755TQ at 7600rpm, and 20psi boost. It loves the high rpm no doubt. A little issue with the wastegate controlling the boost, it would slowly ramp in until 7000rpm. We will get the wastegate taken care of before it goes in the car, and put down some 4 digit numbers to the wheels next spring. Going to spin it a little higher in the car as well, ran out of time on the engine dyno before we could turn it up more.
