370 forged motor on 15psi breaking up high rpms
I have a 370 cube forged iron block
callies rods
Diamond pistons
plasma moly rings
ARP studs etc
Top end is LS3 heads Manley NEXTEK 700 lift springs and retainers shimmed properly
LS7 lifters
3/8 Comp magnum pushrods
stock rockers w/ comp trunion upgrade
Single plane intake, fast 4150 throttle body and a carb hat
Borg warner s475 t4 83mm 1.10 ar
godspeed 4" intercooler
46mm precision wastegate
godzilla BOV
th400 stalled auto with 4k stall
has 74lb injectors @63 psi
Truck coils with heat sinks
MSD wires
NGK BR7EF plugs gapped to 26
car is tuned at 11.3 a/f and stays there consistently never lean spikes
16 degrees of timing on 93 pump gas
Car pulls like crazy and never noses over but you can feel it stuttering in the upper rpms even though it still pulls...
makes around 12-13lbs in first and second and up to 15 in 3rd gear
and ideas?
The entire setup has less than 200 miles on it..
thanks
callies rods
Diamond pistons
plasma moly rings
ARP studs etc
LS7 lifters
godzilla BOV
MSD wires
and ideas?
thanks
I gapped them to .022 I will take it out in a bit and see how that feels.. it seems like it even has some hesitation while cruising.. so maybe its in the ignition or tune...
well i pulled the plugs and went to .022 and it runs great....actually too good..lol it boosted up to 18lbs
I think it had a boost leak too so with the combination of the boost leak fixed and it not blowing out the spark it also is boosting higher...had to turn down my manual controller...
Thanks for the help guys!!
oh yes it is stock hollow LS3 valve and the cam is pretty healthy
23x/24x - 64x/64x 116+4
not trying to be secretive I just dont remember the exact numbers off the top of my head
Yea I need to get a meth kit on it for sure that's next on the list.. Also need to address my crankcase ventilation. We done away with everything and put breathers on the valve covers. Any suggestions or diagrams.. I am going to turn the boost down to 10psi so I don't break anything
If you're able to take the timing down from 16 to 13-14 and the boost to 15psi I would feel semi-comfortable running that.
Would I hold it to the floor everywhere I went with that tune? No, but if your IAT's aren't ridiculously high then you will most likely be ok.
With your cam your DCR is lower than most on here with smaller cams so you're killing some cylinder pressure in itself with the cam you have, I just wouldn't be running that much boost on pump gas alone.
With alky at 100% I'd have no issues running 18psi and 15-16* all day with pump 93, but if it were mine I would put it at 14-15* 18psi and lean it out a half a point if/when you add methanol injection.
