diamond pistons? can these be used
Old 07-14-2012, 06:57 PM
Boosted Firehawk's Avatar
Default diamond pistons? can these be used
on a stock crank 6.0 with forged rods?
http://www.cnc-motorsports.com/pisto...030-bore.html/
also any one using these pistons on a 370 cube
Old 07-14-2012, 10:07 PM
killernoodle's Avatar
No. Stock crank is 3.622" stroke, those are for 4.0" stroke cranks, so you would either need longer rods than 6.125" or a 4.0" crank.
If you put that piston in with stock length rods and stock crank, it won't come up to the top of the bore and you will have super low compression.
Old 07-15-2012, 12:45 PM
87silverbullet's Avatar
The part # you need for a 370 is 11517. That piston is for a .927 pin.
Quick Reply: diamond pistons? can these be used
