8 second stock 5.3 THE GRENADE
Old 07-16-2012, 05:43 PM
silver_82's Avatar
Default 8 second stock 5.3 THE GRENADE
Went to joliet to run true street and make some shakedown runs. Remember I just got it running about 2 weeks ago and didnt have any time for a local track day and decided to go anyhow. Learning how to launch on a turbo car is tricky without a boost controller, but I managed to fig out how.
my 1st pass with the combo, leaving with 0 boost, and on wastegate springs (13psi) netted me a 9.8 @145 with a horrible 1.7 somthing 60ft. It looked like I took off from a stop light then whoosh it took off.
I had 2 more practice runs, basically just trying to fig out how to launch, went 9.7@145 then 9.2@147. still on wastegate pressure
Holley hasnt released boost control yet so I rigged something up that I though would work, it failed, it would start to build more boost then go back to 13psi then build it up and back down. Surging basically. But I left it hooked up anyway.
Heres the results from my 3 runs after the true street cruise. We are required to run 30 miles and go back to the track and we cant do anything to the cars, except lower tire pressure. No hood pops, no adding fuel, no tuning, ect. Then we run 3 hot lap passes
1st: 1.39 60ft (peddled it, cause it pulled a big wheelstand)
5.84 @122
9.05 @153
2nd: 1.61 60ft (my fault, I didnt build enough boost)
6.3 @119
9.58@150
3rd: 1.31 60ft
5.73 @121
8.97 @151 (my first 8sec pass, woo woo)
I wish my 1st run went better cause it would have been an 8.8 I think. The IAT's by the 3rd pass were +245* and the trans temp was 230*
Going to put a boost controller on it and maybe an intercooler too. See how deep it will run into the 8s when I turn up the wick.
Old 07-16-2012, 05:46 PM
B18B1LS1's Avatar
Good grief! Awesome!
Old 07-16-2012, 05:49 PM
JAX04's Avatar
Good damn deal man! How much boost was on the 8 second slip?
Old 07-16-2012, 05:50 PM
billetproof97''s Avatar
Some nice runs to me! Nice setup too!
Old 07-16-2012, 05:52 PM
silver_82's Avatar
It wasnt a steady pressure, it would go up to 19 then to 13 on all the runs, it was like a rocket for a sec then it felt like you hit the brakes, then a rocket again, and just cycled like that. Ill see if I can pull a log out and fig out how to post it
Old 07-16-2012, 06:05 PM
a4ls2goat's Avatar
Holy damn. Keep that boost steady and it'll go faster forsure!
Is this on a lm7?
Weight?
Old 07-16-2012, 06:21 PM
three83'camaro's Avatar
Whats your race weight? that grenade is a good analogy for what i predict happening to that poor stock 5.3. lol
edit: i just saw your other thread and it answered both of my questions. How much timing are you running in the wot rpm x mg/cyl cells?
Old 07-16-2012, 06:49 PM
silver_82's Avatar
yes, a stock lm7
If it blows up then Ill go spend anoth $175 on another 5.3 and run it some more, but I think itll last a good little while. No noises thus far, good oil pressure, good compression, thing runs like a champ, hardly any vapor coming out of the breather too. This engine was a way for me to learn how to do my own tuning so itll get pushed very very hard this season.
I weighted it at joliet and it was 3160, alot less than I expected to see, I figured it was going to be close to 3300
Old 07-16-2012, 06:51 PM
Bloodbath's Avatar
dude, this thing is so much more badass without an intercooler. good job.
Old 07-16-2012, 07:06 PM
4DRUSH's Avatar
Nice job
Old 07-16-2012, 07:08 PM
IH8FORD's Avatar
Subscribed. Nice work I'm planning a turbo project with a 2nd gen firebird and ls1.
BTW how did you place in the true street race. that's a good 3 pass average.
Old 07-16-2012, 07:18 PM
SSZ
SSZ's Avatar
Yeah. Great times for sure especially for your first time out. That thing is flying and there isnt much for mods to the motor. How do you like the Holley setup and are you using stock coils? Truck looks killer by the way!!
Old 07-16-2012, 07:49 PM
dudeman's Avatar
what turbo?
Old 07-16-2012, 07:51 PM
stangtrader's Avatar
Damn...thanks for some inspiration lol
Old 07-16-2012, 07:59 PM
02_camaroz28's Avatar
Old 07-16-2012, 09:09 PM
2baditsnotachev's Avatar
What is your final timing at 13lbs? Im at 24 at 11lbs and I keep having piston slap problems so im wondering is my timing too aggressive?
Old 07-16-2012, 09:13 PM
jleews6's Avatar
151 mph is strong. Get some passes on it and you will be well into the 8s.Very impressive for sure. I didn't see it in you other thread bur what cam are you running?
Old 07-16-2012, 09:27 PM
Bigrob339's Avatar
Nice man...congrats! I was there all Saturday wondered if you were there, must have just missed your runs that day!
Old 07-16-2012, 09:33 PM
silver_82's Avatar
I dont feel comfortable giving out tune info because every combo is different. Dynamic compression and static comp will change the ignition lead reqirements as will the fuel type and so on.
I keep reading where guys are running high 20*s or even 30* of timing with lots of boost but mine is not one of them.
Old 07-16-2012, 09:38 PM
silver_82's Avatar
My average was 9.20 and I got runner up. I was stoked, i went mainly to make some test hits and see if it would 60ft decent
Quick Reply: 8 second stock 5.3 THE GRENADE
