LQ-9 370ci with LS-3 Heads and Intake Swap
Old 07-17-2012, 01:33 AM
trnsfmr99's Avatar
Default LQ-9 370ci with LS-3 Heads and Intake Swap
I just ordered some LS3 heads and intake. I have an LQ-9, forged internals, running 60lb injectors, thru a T-56 and 3.42 gears, with a T-76 f/m turbo and 317 heads and an LS-6 intake (no port work to the 317's or the ls-6 intake). Last run, the car did around 530 rwhp on mustang dyno. What am I to expect with the LS3 setup on my car?
Old 07-17-2012, 01:34 AM
trnsfmr99's Avatar
In addition, in order to do this swap, what parts will I need (worst case scenario) and could I use any of my current parts with the new heads and intake?
Old 07-17-2012, 02:32 AM
WheelsUp84z's Avatar
you'll need a Throttle cable bracket, ls3/l92 specific rockers, and if you dont have aftermarket rails, you'll need those too. Or find a set of l76, ls2, or ls3 rails. Also a 90mm TB (4 bolt)
Old 07-17-2012, 04:47 AM
trnsfmr99's Avatar
Ok, thank u
Old 07-17-2012, 01:24 PM
CHRIS'S 98 SS's Avatar
Is this swap worth that much hp? I may build a 370 with ls6 and 317 for budget, but if it's worth the extra hp I may do the same.
Old 07-17-2012, 02:24 PM
Reject's Avatar
I know mast has some bad *** heads for cathedral ports
Old 07-17-2012, 04:04 PM
87silverbullet's Avatar
Originally Posted by trnsfmr99
Ok, thank u
Mannnn, you know you're supposed to call me first before doing something like this! Pm me or call me.
Old 07-19-2012, 06:10 PM
trnsfmr99's Avatar
87, we will talk again. Everyone else, whats yalls opinions on how those heads and intake will perform for a forced induction setup?
Old 07-19-2012, 09:38 PM
Got a lil busy man. I'll call you during the day tomorrow.
Quick Reply: LQ-9 370ci with LS-3 Heads and Intake Swap
