LS9 cam not good with turbos???
Old 07-17-2012, 07:48 PM
quik67's Avatar
Default LS9 cam not good with turbos???
Seems I have heard more negative reviews with the LS9 cam and turbos. I am looking for something for my 5.3 that will have good low to mid range torque and pull like hell up top. Would the GT2-3 be a better option or TU1?
Or should I just go with a LS6 cam and be done.
Which of these would most likely produce more torque out of boost?
Old 07-17-2012, 08:18 PM
a4ls2goat's Avatar
I'm using the ls9 cam on my 70mm, 5.3 setup. Works perfect. Pulls hard all the way to 6500rpm and wants to keep pulling.
Old 07-17-2012, 09:02 PM
WheelsUp84z's Avatar
not bad for a $95 cam new from GMpartsdirect
Old 07-17-2012, 09:26 PM
1sick-Z's Avatar
It works. Definatley best cam for the $$$
Old 07-17-2012, 10:01 PM
a-low's Avatar
It may be 95 $ but factor in the cost of the front cover and i think cam gear is different?
Old 07-18-2012, 07:10 AM
turbocamaro125's Avatar
buddy has 4.8 s472 t6 turbo with ls1 intake and ls9 cam and it spools at 2600 and runs great for 12.5 psi........new cam is like maybe 20 bucks. I got him a ls9 cam and gear for $124 with tax lol
Old 07-18-2012, 07:15 AM
Moderator
denmah's Avatar
its working pretty damn good in a bunch of our 10 second 4.8 setups
Old 07-18-2012, 03:24 PM
i'd like to know where you got a new cam for 20 bucks. 95 is the cheapest I've found it, i've seen it as much as 160.
Old 07-18-2012, 04:29 PM
HRHohio's Avatar
Horrible cam... I have like NO TRACTION anymore! Damn!
So bad, Lingenfelter discontinued one of their cams.
"This is the GM factory 2009-2012 LS9 ZR1 camshaft that works excellent in many supercharged or turbocharged applications. The LS9 camshaft is 211/230 @.050 valve lift and .558/.552 lift with 1.7 rockers and a 122.5 centerline.
Before the LS9 was introduced LPE used the GT7 camshaft that John Lingenfelter designed in 2001 to be the perfect camshaft for boosted LSx applications. The GT7 was 208/230 @.050 valve lift and .554/.546 and 121 center line this camshaft produced excellent power and still had great street driveablity. In 2009 GM introduced the LS9 in the C6 ZR1 supercharged Corvette engine. After comparing specifications on the camshaft and finding out how economical this is due to it being mass produced Lingenfelter discontinued the GT7 and started using the LS9 in supercharged or turbocharged applications.
The LS9 camshaft is a 3 bolt design and will use the Lingenfelter 3 bolt cam conversion kit if you are installing it in a single bolt application like the 2007 – 2010 LS2 or LS3. If you are installing it in an earlier LS1 or LS6 engine with the cam sensor at the back of the engine you will need a 2005 LS2 front cover, 2005 1x cam sprocket, camshaft extension harness, 2005 LS2 chain dampner."
http://www.lingenfelter.com/mm5/merc...w=&range_high=
Old 07-18-2012, 05:06 PM
quik67's Avatar
Ok guys Im convinced !
I will go with the LS9.
Thanks for all the replys.
Old 07-18-2012, 05:54 PM
HRHohio's Avatar
It is a good budget turbo cam... you won't be upset... easilly 50 hp more than a stock cam will get you, overall.
Don't get me wrong... if you were doing competitive racing, you might think about having someone professionally spec a cam for your exact setup. But for what it sounds like you're shooting for, great cam.
Old 07-18-2012, 06:55 PM
2baditsnotachev's Avatar
How does it compare to the ls6 cam though?
Old 07-18-2012, 09:10 PM
Cam gear sorry
Old 07-18-2012, 10:27 PM
HRHohio's Avatar
Better than the LS6.
Here are some Cam Specs:
LS6 Cam (’01): 204/211 @ 0.050; 0.525/0.525; 116 LSA
LS6 Cam (’02+): 204/218 @ 0.050; 0.555/0.551; 117.5 LSA
LS9 Cam ---->: 211/230 @ 0.050; 0.562/0.558; 122.5 LSA
Interestingly the LS7 Cam is VERY similar to the LS9 Cam but has a tighter LSA and a little more lift:
LS7 Cam---->: 211/230 @ 0.050; 0.591/0.591; 120.5
I'm thinking that the tighter LSA on the LS7 cam will help with the low end (not in boost) torque and be a bit more aggressive down low.
http://www.chevyhiperformance.com/te...n/viewall.html
Just my thoughts...
Note: The GT7 camshaft by Lingenfelter had a 121 LSA, but a little less lift.
Old 07-19-2012, 07:21 AM
Stangkilr's Avatar
LS9 cam is working awesome on my setup.
Old 07-19-2012, 08:53 AM
HRHohio's Avatar
Nice! That picture in your sig says it all!
Old 07-19-2012, 10:51 AM
ramairetransam's Avatar
how it do with a procharger p1 on an ls1 ? sorry to ask turbo guys . and hijack
Old 07-19-2012, 11:09 AM
Stangkilr's Avatar
Its a good boost cam period for the money. Its got a stock sounding idle though. If you want a small cam with a Pro-Charger just do like a 224 cam or something.
Old 07-19-2012, 12:39 PM
94'BLKBRD's Avatar
I think the sig pic was with his NA/Nitrous setup, I may be wrong though.
Old 07-19-2012, 01:16 PM
Stangkilr's Avatar
Yeah it was. Its faster now though.
Quick Reply: LS9 cam not good with turbos???
