Catch can idea with ls9 cam?
Old 07-20-2012, 10:44 AM
runninfromthelaw's Avatar
Default Catch can idea with ls9 cam?
Hello all,
So I was wanting to know what do people do with the old cam sensor hole when they use the ls2 style in the front cover. I was just going to plug it, then thought to use it for the catch can.
Has anyone done this or will it even work that way?
Old 07-20-2012, 11:29 AM
HexenLord's Avatar
You mean as an oil return for a catch can? Its possible, ive seen some high mounted turbos use that hole as an oil return.
Old 07-20-2012, 12:42 PM
That or even the vent.
I deleted my AC and plan on mounting the catch can on the firewall. Most setups I see vent from the valve covers, but can you use the sensor hole also?
