Killed it
Killed it
Well, killed #7. Engine developed major crank case pressure, even at idle. Did a leak down, 90% on 7. All he plugs looked perfect, even 7, no metal or funny color. I will assume it has a broken ring land as the rear steam vents are blocked, although seems odd to have no signs of damage on the plug. Have to pull the motor to get the head off sadly. I plan to pull it out tomorrow, until then I'm hoping for the best.
99 LS1
Stock rebuilt bottom end with 15k
Eaton m112 blower
Alkycotrol injection
99 LS1
Eaton m112 blower
Tr6 plugs @ .028
AFR's at 11.2-11.4
not sure on timing as I had it dyno tuned and never looked at it.
93 pump gas
Pulled the motor last night
Pulled the head at lunch today, cyl and piston look perfect. will pull the oil pan tomorrow and pull the piston out. Maybe a broke ring?
AFR's at 11.2-11.4
93 pump gas
This is from #7 on an LS2 GTO engine with a rear mount turbo.
https://ls1tech.com/forums/forced-in...-piston-6.html
Looks like the rings butted/expanded and crunched the piston groove cracking it. Only had 46K miles on the shortblock. About 10K boosted. Bore was also fine luckily and simply honed all of them, ordered 1 new piston, and a set of Total Seal rings.
