Valve float 52-5300 rpm. Than no issue.
Got my car tuned on Sunday. There is an issue at around 5200 ish it sounds/acts like valve float then seems to push through it and rev on up just fine.
Tuner said everything was perfect. 11.4-11.9 A/F, 18-20 deg timing. Never did anything funny until that 1 rpm. He had also mentioned there were issues with harmonics that at 1 rpm or (pitch) they can act like a guitar string plucked to hard and almost go flimsy for a second than the pitch or rpm changes and it can handle the load again.
I just always assumed if the springs couldnt handle the load they couldnt handle it past a certain psi or rpm. Not just miss for a second and keep going no issues.
I figured the LS9 springs would hold 10-11 psi seeing how a zr1 gets 10 psi stock. I already have some Patriot Duals for it I was really just wondered if anyone else has experienced something similar. I am worried changing the springs may not fix it.
OP to answer your question, yes what you are experiencing is a very real situation. We list the frequencies in our catalog for a reason. Every engine at ceritian RPM's create a frequency. the object is to find a spring who's natural frequency is outside of the main operating frequency of the engine while maintianing correct loads and rates to control the valves.
Switching to a different spring will solve your issue. Now what spring you want to run is your choice.
Won't know till you try. if you have different rockers, heads, pushrods, lifters, motor mounts, drive shaft, transmissions ect, ect, you may not get it or you may get it at a different RPM.
