Twin Borg Warner S472s?
Old 08-03-2012, 11:20 AM
N2OBaby's Avatar
Question Twin Borg Warner S472s?
In a street-strip car such as a '84-'88 Monte Carlo 402-403 LS2 or 390 cid LQ9 would a pair of Borg Warner S472s be the hot ticket?
Street tune 8-10 psi would this make around 670-750 FWHP and around 820-977 FWHP with 12-16 psi?
What do Ya'll have?
Old 08-03-2012, 11:25 PM
Fbodyjunkie06's Avatar
402 and those turbo's would be insane. 1500rwhp all day if you built the bottom end right and used a good 6 bolt head and block set-up from ERL or an aftermarket block.
An o-ring set-up would also handle it with 4 bolt heads and block.
If you only want that much power though I'd use the S366's or the S467's
Old 08-04-2012, 01:03 AM
blackonblacksls's Avatar
One of those turbos would make those numbers.
S374 @ 11ish lbs on a 330rwhp NA motor makes 603rwhp on boost. Figure your 402 makes another 100rwhp NA at least. So no doubt it make 700rwhp or maybe 750 with the right turbine and the same 11ish lbs.
That right there is 850fwhp easy.
Old 08-04-2012, 09:09 AM
N2OBaby's Avatar
That is awesome news there that a simple combo can be such a beast.
Old 08-13-2012, 11:30 AM
N2OBaby's Avatar
Instead of the largier Borg Warner S472s how would a smallier set of Comp Turbo 67/67 non-Billet Turbos do instead?
Old 08-13-2012, 11:50 AM
sprayedenali's Avatar
im about to put a pair of s366s on my 5.3 hoping for ~900rwhp
Old 08-13-2012, 01:05 PM
LS1TECH Sponsor
DrTurbo's Avatar
What do Ya'll have?
If you want twins, a pair of 366's would be the ticket. We have made 1300+rwhp with them and had plenty left to go.
Old 08-14-2012, 11:49 AM
N2OBaby's Avatar
Sounds interesting, would be nice to have a low boost setting for 750-820FWHP and a high boost setting for 1000+ FWHP and low 9's-High 8's with all creature comforts intact.
Old 08-14-2012, 12:47 PM
LS1TECH Sponsor
DrTurbo's Avatar
A pair of 366's would achieve that no problem
Quick Reply: Twin Borg Warner S472s?
