Where do I put the 2 o2 probes on my turbo conversion?
What's the best position for LH and RH o2 probe sin my conversion
Help, I've never done an injected turbo conversion before!
please tell me that youre going to have those wrapped and a blanket on it...I fear there might be some serious melting lol.
add them to the collector area, what is this going in?
Explain the application and ecu you intend to use ?
ie, are the o2 sensors you are fitting widebands or narrowband ?
A wideband should be fitted in the downpipe some 18-24" at least away from the turbo. Widebands do not like heat or pressure, so you dont really want them before the turbocharger at all.
Narrowbands it will hardly matter much
It's going in a winch challeng truck, standard 02, standard computer.
So this exercise has been no help I have one person say collector the other say dump pipe.
And given this is going into a totally non road legal vehicle ( I assume ? )...you really dont need any o2 sensors at all, especially factory narrowband ones.
Thanks, i had one bloke say collector and the other say dump pipe, im thinking of just going the dump pipe, my tuner says there not needed, but will help if i can fit them.
And for a narrowband sensor, location really isnt that important as I already described.
