What should your tune look like to get best 60' times?
1st I did a search and lots of information but confused on what actually works for best 60' times on footbrake. What should my timing, afr's look like to get the turbo to spool off the line. Car hits hard once it's in 2nd gear but in 1st it's a dog. (2.13 60') I can only footbrake to 2K before it pushes thru the brakes. Car has T/brake but I want to maximize times on footbrake.
60' 2.14
330 5.466
1/8 7.811
mph 106.36
1000 9.988
1/4 11.448
mph 136.39
on the limiter @ 6200 ( I forgot to change the fuel cutoff by gear)
390, 83/92 turbo
3.50 , 4L80E, 3600 stall
4000lb's
60' 2.14
330 5.466
1/8 7.811
mph 106.36
1000 9.988
1/4 11.448
mph 136.39
390, 83/92 turbo
4000lb's
i think your converter is way too tight. If your converter was made to stall at 3600 w/ the amount of power you have... you have to consider the more TQ an engine makes the higher the stall speed, so if your engine makes hardly any TQ out of boost its going to be tight as hell.... your 3600 might be more like a 2200.
My converter is a BTE3800, I can foot brake it up to 4200 and 11psi. Your 1st gear is lower - 2.48, I have a PG w/ a 1.80 first gear....more lag on the engine easier to build boost for me..
standing back and looking at the whole package I've found a few thinks that I need to address, 1st off this is a new build so it's still being sorted.
1. I think I have a exhaust leak preturbo
2. The afr's going into boost are 11.3-11.5 I think I need to raise the afr's and bring them down as boost goes up
3. I'm thinking I need to have the converter restalled loosening it up to flash higher but also need to tighten it up on the top end. I picked up 9mph by locking the converter in 3rd gear. 127 to 136mph
4. I went out and footbraked the car and I can get 2200-2300 before it starts pushing thru
Repeat after me: the most important part of a turbo automatic car is the converter. I would only run a ptc, pro torque , ucc or fti converter in a turbo car. A good turbo converter is loose enough down low to build boost and couples hard up top to have very little slip.
I appreciate all the replies
