Catch Can/PCV question on cleanest set up
This is been beat to death but I am not looking at what's the best system....I am looking for the best and cleanest looking system. I want to have the least amount of hoses in my engine bay and would like to avoid a filter on the valve cover. The engine is a LS2 Twin Turbo. I don't mind the look of bungs welded into the valve covers but does that run to seperate cans and what is the fresh air source, a filter on the valley cover?
I guess I could hide the can somewhere but looking for opinions and pics of set ups that are with little or hidden hoses.
I did an rx catch can, and hell it looks so good I wanna show it off. and its black so it looks factory, and its neat.
it uses 3 hoses from what I remember. But I do use the filter. which looks pretty good IMO. some people recommend venting them both. this video is pretty informative. the mike norris is supposedly a nice one too
thanks
i welded the -12 fittings on, i also welded a baffle directly below the hole. i dont get any smoke or oil speckles on my bumper
for oil fill just unscrew one hose, stick funnel in fitting on valve cover
the tank on the head is a degassing/surge tank for the coolant, coolant head ports go to the top of the tank, bottom port on tank goes to pump suction
i enjoy that i never get that wiff or smell of blowby ever
thanks
-doesn't catch anything...I guess it's not catching it's just evacuating??
-doesn't work well on anything other than open headers......true, do you have mufflers?
-blast oily mist directly on your o2 sensors possibly cat converter....guess you could evac after the O2 sensors??-not 'legal' emissions-wise.....guess so but my car won't need to test
it is hooked in far down stream of the O2s. i have two magnaflow mufflers in series, stocklike quiet. not worried about emmissions where i live.
and i honestly dont care if there is much suction or scavenging effect, i just know it gets rid of my crankcase gasses and i havent had a problem in 3 years and it is on the street 99% of the time
even with hardly any scavenging i see still better than venting to the atmosphere because i never smell it and dont have to have a catch can
