built engine with Melling 10296. 28psi PULL ENGINE ?
well cold im getting about 40-45 psi at idle, after it is heated up it runs at about 25 psi as you rev it to 2500-3000 rpms the oil pressure goes up to 45 psi. oil im pretty sure is 0w-40 moible
The engine has about 10k miles on it running 850rwhp,
I dont know what the oil pressure was when installed i just feel its to low should i just pull it now and do a refreshing ????
Is this a turbo engine? I know on my setup I was told by Heinz I needed valvolie vr1 racing oil 20w50 because the oil got so hot going through the turbo. But I don't know what kind of FI you have
Well, old school small blocks ran just fine with 20-25psi hot idle oil pressure but the consensus here seems to be that that's to low for an LS based engine. Put some 20w-50 VR1 in there and see what happens. Does the pressure rise when you get on it? Also the rule, I assume is still 10psi pressure for every 1000rpm.
The pressure isnt low enough to cause any concerns from a lack of pressure though.
As to whether or not it should be higher is another debate.
Ive the same HV pump on mine albeit with the lighter spring. It still makes around 35-40psi at hot idle, with lots when revving lol
I'm using a 10-60 though. I do not like thin oils.
im guessing it the oil and its thinning out to much while hot. cause right after a drive it around 28-30 psi and after a while of idleing and reving it lowers to 20-25 psi. I will be moving up from a 0w-40 oil to a 15-40 or a 20w-50. But i want to have some one weld in more oil pan for the car so i can add a QT or 2
Im guessing the engine is fine so the rebuild will be later in life again. Just going to up the boost
