5.3 turbo
5.3 turbo
I have a silverado 2009 flex fuel with displacement on demand (DD). starting building a turbo kit. Do not know much about the DD. i know that on the tuning has to be disable but not sure if internal parts have to be changed. What would my limitations if just turbo it?
Thanks
Tony
Thanks
Tony
A 120 views and nobody wants to comment. Needs help and i know someone here knows.
Will appreciate the information or where i can get it have search the forum and nothing comes up.
Tony
Tony
Thanks Chuck but I do know what DOD is and that my truck do have it and that is the only thing will find on that link. I want to know what is going to happen when I boost the sucker with 8-10lbs. Do i have to change lifters, cam, timing chain or what would be the maximum boost i can run with everything stock just by deleting DOD from engine management.
Thanks
Tony
Thanks
Tony
ive installed maggie and edelbrock supercharger setups on vehicles with dod and they have you replace the valley plate (for clearance reasons) and the new plates dont have provisions for the solenoids. You reuse the gasket and put on the new plate and turn off dod with hp tuners or efi live. Ive never needed to replace any lifters or anything. Id say just turn it off and your good to go
