Oil Cooler
Its possible that it could cause a pressure drop or a restriction plus you are cooling the oil right before it gets superheated by the turbo. I dont really think that the engine will benefit from this. I have a scavenge pump on my turbo drain and the pump feeds the oil cooler then returns it to the pan. You could always do a sandwich adapter above the oil filter and run it to the cooler that way.
