Low Compression F1R combo-975 rwhp
Old 09-13-2012, 08:49 AM
eb02z06's Avatar
Default Low Compression F1R combo-975 rwhp
My buddy Frank's Virginia Speed 402, 9.1 CR, AFR 225's, FAST 102, 90mm TB, CCP cam and 10 rib setup combo.
http://youtu.be/nWP3rEE2Muo
We went with a lower compression for the "safe" setup since this car is more standing mile use.
Going to maybe try out a few other things to break the 1k mark.
Old 09-13-2012, 09:44 AM
venom ws7's Avatar
Awesome setup and work like always man...
Pulls hard all the way to 6700+rpm
Old 09-13-2012, 09:47 AM
MR2liter's Avatar
Nice #s! Which cam do you have in there?
Old 09-13-2012, 09:52 AM
eb02z06's Avatar
Thanks buddy-did you get my PM on the CF forum?
Old 09-13-2012, 09:55 AM
eb02z06's Avatar
For some research we tried a really big one, it's a 253/259-we wanted to see how far it would pull.
It did pull right to 6500 but you would figure it would of pulled higher-this just verifies to me that the intake runners are too long for anything past 6500.
Old 09-13-2012, 10:44 AM
NEED MO POWA!'s Avatar
impressive, what psi? what pulley combo?
Old 09-13-2012, 06:37 PM
eb02z06's Avatar
21lbs, 8" crank with a 4.125" blower.
Old 09-13-2012, 08:46 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks good. Just dropping the cam to a low 240 would probly hit the 1k mark by bringing up dcr.
Old 09-13-2012, 09:00 PM
eb02z06's Avatar
I have to finish up another F1R combo next week that is very similar but has the 240/254 cam but the compression in that motor is 10.1
So it will be interesting to see what happens.
I think on this car I may swap out the cam to something even smaller-I was thinking along the lines of my 236/250 cam.
Old 09-14-2012, 07:46 AM
LS1Tech Sponsor
Slowhawk's Avatar
Should do very good. Most of out centri car's are 10-1 minimum. Bigger cams are 10.5-1 to 10.8-1.
Old 09-14-2012, 03:56 PM
helicoil's Avatar
Nice numbers Arun!
Old 09-14-2012, 06:09 PM
RAMPANT's Avatar
Frank's car is a sweet ride. Saw it in person a couple weeks ago at a BBQ.
Sounds mean as hell too.
Good job Arun.
