Holley EFI boost Control!?! Where is it?
I'd love for some real info on the progress of this from Holley, like real info none of that were working on it non committal doctor talk. What's a timeline, what are the holdups, goals. We are the bread and butter consumer. I'm using an AEM Tru-Boost because of the lack of interface! Most of us (me included). Have done the coil dance and ended up with the brick sized coils, don't get me started on the locating a plug and play harness!
A lot of us bought this under a "one box solves all" concept..... Hell I could have put a megasquirt, msd spark control, and ams-1000 in my car if wanted to. The Holley has some really great features so............ Let's see them.
Holley? Uncle Robin?
Andy
Andy
I as well as some others have the beta version and have been helping them out with testing and refining the inferface. It has alot options and adjustments/saftey measures. Top notch so far and is leaps and bounds better than an ams 1000.
Thanks for the post, any info is great. Holley as a company rolling out the efi has been less than stellar. But, its a very capable unit for the price! They just seem to be doing a lot of R&D in the process. Does the boost control require CO2?
You can use co2 if you want but its not required. Id put up screen shots and tell more about the software and what it can do but im unsure if im suppost to without their permission. Its a full featured boost controller that has lots of types of control not just boost over time like an ams 100.
LS1Tech Sponsor
Remember what is posted is a BETA and things can change on the final release.
The current version is a little complicated for the average tuner and we will probably develop some PID's to make the initial setup easier.
Doug is on the Hot Rod Power Tour this week utilizing every option on his Holley Dominator EFI.
Trans Control, Water Meth injection, Nitrous as well as Boost Control.
Robin
Go for it!
Robin
Robin
Hell yeah, please, post some up
holley boost control sneek peek
heres some screen shots, as you can see its got lots of different ways to control boost, via time, gear, rpm, manual, speed, ect. has built in saftey limits, can control the increase in boost by pwm only, dome only, and dome+manifold which is 2 controllers interlaced.
I know its hard to wait but its going to be worth it, by far the best and most complete boost controller on the market, and it has lots more features that I havent shown, and my favorite part of the holley efi system is the inputs and outputs, and how they can be used to control everything on the car. If your thinking about buying a standalone dowload the free software and play with it. its very user friendly. And it works perfectly with 24x sensors, go ask someone with a BS3 if they had the same luck.
The source supply pressure is the compressor discharge port in that case. Thats how im using it. C02 is nice but i didnt want to have to buy a bottle and run a line when this way works perfect for me
If you want to put pressure on top of the gate to force the valve closed u can command it but you wont have any until you have some boost built.
Exactly the same way any boost control setup works. With compressed air from the turbocharger.
Using a higher pressure source can have benefits if you need to do very specific things with boost control. Which about 90% of people do not need.
