Ring gap for boosted 5.3
Old 02-05-2016, 01:38 AM
tinoi30's Avatar
Default Boosted Ring Gap
You can use the Wiseco piston ring gap formula in the link below. http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
From looking at the formula for a stock 5.3L engine which has a stock cylinder size of 3.78inches you can multiply:
3.78 X .0050 for the top ring
3.78 X .0055 for the second ring
Results are as follow:
Top ring .019
Second ring .021
Therefore, I have no idea how people came up with bigger ring gaps. If there is other formulas, I would like to know of them.
Old 02-05-2016, 12:32 PM
ablakez28's Avatar
Top ring .019
Second ring .021
You would gap the rings on a turbo build more similar to a nitrous/blower car. Their spec in that link is .0065 and .0070 for a blower race setup for example.
top at .0065 = .02457
bottom at .0070 = .02646
This is about where I would put a 5.3 ring.
On 6.0s I uaually do a .028 and .030
408 in my car i ran .030 and .032
I have not had any issue much like many others running a little bit looser gap. You will find out quick if its too tight though!
Old 02-05-2016, 02:08 PM
Forcefed86's Avatar
Top ring .019
Second ring .021
Depends on the piston/cylinder expansion rates and how hot they will be. The fuel/tune also plays a part in piston operating temperatures. The hotter it gets the more it expands, the more it expands, larger the gap needs to be.
You're looking at "street moderate" Call up weisco and ask them what the hell that even means? Guys pushing serious boost on pump gas generate a ton of heat. I've seen the top ring lands pulled off a .022 gapped top ring on a pump gas setup. I know some E85 guys run them at .018 without issue too.
I noticed what I consider excessive blow by gapped a .028/.030. .024 on the top ring and under I don't seem to have any issues.
Old 02-05-2016, 09:00 PM
RonSSNova's Avatar
I gapped the top to .024". Was .019" before gapping. 125k mile engine.
2nd ring was .028 as delivered. I left them alone.
No blow by.
FWIW, the bottom ring is the 3 piece oil ring. Leave it alone.
Our stock Pistons have the top ring down a bit on the piston. A purpose built blower or turbo piston will have it quite a ways down.
Ron
Old 02-06-2016, 06:24 AM
forcd ind's Avatar
I did .022/.024 based on the piston manf. rec
In reality, I wonder how many actually hit the mark if your using one of those little hand crank grinders-first you have to get the end square, grind, meas., grind again and still keep the end square-I know I cant get it perfect every time, lol.
When my block was at the machine shop, I used their expensive grinder, meas. what I had and what I wanted, set it up and go, but the average do it your selfer isn't going to have that
I think most important, just make sure they are not to tight
Old 03-17-2020, 07:22 PM
Tom Aldrich's Avatar
Default Sti
Originally Posted by JaYZeig
stock ring gaps in my 02 lq4...
no meth, 640 rwhp on 10pounds boost..i wouldnt even
mess with em inless youve got bigger plans eventually
Still run well?
Old 03-17-2020, 10:36 PM
Dragframe's Avatar
Originally Posted by Tom Aldrich
Still run well?
Theres one I built 13 years ago still running around town. 10psi the entire time on a SBE 5.3
The following users liked this post:
Tom Aldrich (03-17-2020)
Old 03-17-2020, 10:40 PM
I have an 06 tb ext 5.3 i would like to build. Looking for about 600 to wheels and want 4wd working/ maybe 33's.
Old 03-18-2020, 09:48 AM
silversweetZ's Avatar
I'm throwing 15lbs at this thing everyday trying to break it everytime I drive so I have a reason to build my 6.0 on the ground.....it eats it up with those 15 year old Incon twin turbos
SS2win (04-28-2020)
Old 03-18-2020, 09:16 PM
stacy moore's Avatar
So what ring gaps did you end up going with?
Ncie set up
Old 03-19-2020, 04:27 AM
Ncie set up
.024 & .028 with zero blow by. I'm going to go ahead and build my 408 this summer and use .026 & .028. This 5.3 was a junkyard motor, all I did is tanked it and threw in an 2002 ZO6 camshaft. Can't break these things!
Quick Reply: Ring gap for boosted 5.3
