Tired of running so slow.
Old 09-23-2012, 07:57 PM
4kiro's Avatar
Default Tired of running so slow.
I am tired of running so slow. Giving procharged Camaros everywhere a bad name. I decided to put some money in the car and try to beat my 13 second runs. I am installing in the next few weeks some 317 heads milled 3 hundreds with TSP springs, TSP 7.400 hardend pushrods, MLS headgaskets, Brute Speed blower cam, LS2 timing chain. Going to a Speed density tune. One question I still have is should I buy ARP head studs or get the Pro Comp head studs. If I get the Pro Comp I can afford a meth kit. If I get the ARP then I cant get the meth kit. Car is a street car and hoping to last on this setup until next winter when I get a built 408. What would you guys do?
Old 09-23-2012, 08:12 PM
PRAY HRD's Avatar
i can't give any input on the comp studs as i'm not familiar with them, but what's your slip look like? ever thought about going auto depending on how much that's hurting your time? (flame suit on lol)
Old 09-23-2012, 08:25 PM
4kiro's Avatar
I have have a slip on me right now. On about 10 psi I ran a 13.01 at 113 mph. 2.15 sixty foot. I was using Nitto 555r 17 on stock ZR1s wheels. After this mods I dont see much of an improvement then the M6 is coming out.
Old 09-23-2012, 08:46 PM
gsxr1k2's Avatar
113 mph on 10 psi??? Got a boost leak!?
Old 09-23-2012, 08:56 PM
MUSTANGBRKR02's Avatar
2.15 60' you don't need anymore power.
Old 09-24-2012, 12:02 PM
JRENIGAR's Avatar
What does it dyno? MY setup with almost 9lbs run 12.08 @ 117 with a 1.95 60ft. Hp #'s in sig. this is with a full wieght car with 2 12's in a box, spare and jack in back, and a back seat full of crap that shouldnt have been there also. Dont know what it weighs but its alot more than stock...
Old 09-24-2012, 01:17 PM
josepy121380's Avatar
The one and only time i ran my car at the track i cut a 11.8 on the 6 speed with the p1sc at 8lbs. 121mph.
Old 09-24-2012, 01:20 PM
willizm's Avatar
What do you have for suspension? If it's stock try getting some decent shocks, LCA with Relo brackets, torque arm and panhard bar. Power doesn't matter if you can't put it down.
Old 09-24-2012, 01:37 PM
hardbodeez's Avatar
Ditto. Car is not making any power.
Car isn't making any power hence the mph. Spending your time worrying about suspension right now will yield minimal gains compared to finding out the real problem.
Old 09-24-2012, 01:45 PM
4kiro's Avatar
Car dyno was 510 and 498 on 10 psi. Car weight was 3680 with me in it. I have AGX shocks, front is stiff as you can get and the rears are in the softest setting. Eibach lowering springs. I know the shocks and springs aren't the best but I still can't believe I am only seeing 113 mph. I have a AFR gauge and the tune doesn't seem to bad. I see about 11.1 while it's pulling. I have 60lb injectors with twin pumps.
Old 09-24-2012, 03:35 PM
TurboMark8's Avatar
510wheel should get u into the 11's no prob
Old 09-24-2012, 06:38 PM
JRENIGAR's Avatar
I dont understand this comment. If the pulley combo dosent equal what he is getting I could see that, but, no reference to pullie combos has been made. Granted, most 10 psi combos are faster than 113mph 1/4 mile. If thats what you were referring to, I agree.
Old 09-24-2012, 06:41 PM
HioSSilver's Avatar
Dam....your slower than full bolt-ons at this point.
Old 09-24-2012, 06:44 PM
JRENIGAR's Avatar
Could the clutch be slipping?
Old 09-24-2012, 07:19 PM
4kiro's Avatar
No the clutch is holding up fine. It's got a LM performance clutch. I have double and triple checked all the clamps. The only thing that worries me is that the hat is pressed against the fan shroud. It might be causing a shitty seal.
Old 09-24-2012, 07:34 PM
bwkmaro's Avatar
not to be offensive but that has to be driver error. the only reason i would say that is because you are actually thinking of removing the 6-speed because the car is performing bad. the prob is NOT the 6-speed. 500 whp is wicked fun but adding more hp at this point is not going to fix what ever the issue is
Old 09-24-2012, 08:02 PM
wws699's Avatar
You need to stiffen the rear shocks and loosen the front
Old 09-24-2012, 08:15 PM
RacerXLs1's Avatar
Go th400 or 4l80e instead of buying those parts and put a good drag radial on it , you will thank us later...
Old 09-24-2012, 08:21 PM
HydroStream6's Avatar
I'm with this guy ^^^
Old 09-24-2012, 08:34 PM
4kiro's Avatar
I meant to say that i have the rear stiff and the front soft. Yeah I know that I am no Juice with a M6 but I am not bad either. This car is a street car, I go to the track once or twice a year. I already bought the parts just have to get some time to put them on. Go Pro videos will be posted.
Quick Reply: Tired of running so slow.
