turbo sizing for a 408?
Old 09-30-2012, 03:52 PM
dmaxvaz's Avatar
Default turbo sizing for a 408?
Bought a 408 shortblock with -20 pistons in it, and i need a turbo to match it. The engine is going into my 07 trailblazer ss, with a 4l80e trans. This is my daily driver, and want to be somewhat streetable with pump gas, and run 110 when needed. 800 hp is my goal. The turbo will be mid mounted (underneath) and dont want laggy spoolup. I already have a 76 mm ball bearing turbonetics turbo with a. 96 a/r exh housing, and i am thinking this is too small?
Old 09-30-2012, 07:35 PM
overhere's Avatar
really want to hear opinions on this.
Old 09-30-2012, 07:41 PM
67maro's Avatar
Precision GT 42-76 would be a great option that would give you room to grow. Supra guys are having really good luck with the billet 6766. People are making 750whp on it. It all depends if you want 800whp or 800 crank which are entirely different numbers.
http://realstreetperformance.com/sto...30hp-2710.html
Old 09-30-2012, 07:42 PM
ittwgn's Avatar
what size turbine wheel is on the 76mm turbonetics ??
Cam72aro's Avatar
gt91 here on my 408 and I know many other 408's with a gt91 on it.
Old 09-30-2012, 09:46 PM
dmaxvaz's Avatar
I think its a 68/78 mm wheel
Old 09-30-2012, 09:59 PM
Grr
Grr's Avatar
so you have a BB TC76
too small man
sell it and get get a bigger single or smaller twins
twin tc61 or 66 would be a good choice or Comp turbo has some good small journal bearing units
single I would do a GT76, or GT80
Old 10-01-2012, 03:57 AM
dmaxvaz's Avatar
too small man
Okay, how about a B/W S480 w/racecover , with a 1.32 a/r exh hsg, 88/96mm turbine wheel, and a 80/113mm comp wheel? Have one of these too. Would a quick spool valve work?
Old 10-01-2012, 11:10 AM
Grr
Grr's Avatar
S480 is perfect, spool valve works I did one on a 6.0 s475 and it was awesome
Old 10-01-2012, 03:21 PM
LS1TECH Sponsor
DrTurbo's Avatar
Our new S400-80mm Billet ETR-HO is making some ridiculous power and spools a good bit quicker then the previous versions since the comp wheel is 20+ grams lighter as well. With the new 11 Blade Billet ETT design its an easy 1000hp capable unit.
Old 10-01-2012, 03:24 PM
TheLS1Lover's Avatar
If you have a TC76, run two of them. I would run twin GT35s or GT37s for packaging. Something around the 62-67mm would be sweet on a 408.
Old 10-01-2012, 11:12 PM
SUPERMAN_00TA's Avatar
GT91 Here too!
Old 10-03-2012, 08:53 AM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by SUPERMAN_00TA
GT91 Here too!
Yeah GT91 is definitely no slouch.
Old 10-03-2012, 07:39 PM
overhere's Avatar
how do you think a set of pt7675 on a 408 would work out?
Old 10-04-2012, 03:26 PM
Enough to lift the heads off the block. The PT6766s if you want to go big. But the PT6265s would be sweet on one. Fast spool and 1000rwhp would be easily attainable.
Old 10-04-2012, 04:16 PM
c0ncEpT's Avatar
A PT88 is cheap and fits in a tight area. Not a bad option either.
Old 10-05-2012, 12:49 PM
overhere's Avatar
Thanks ls1lover.
Concept whats the turbine size?
Old 10-05-2012, 01:05 PM
c0ncEpT's Avatar
Originally Posted by overhere
Thanks ls1lover.
Don't quote me but I'm pretty sure the PT88 uses a 94mm exhaust wheel.
Old 01-14-2017, 05:31 PM
lsx02408T's Avatar
Default turbo recommendation
FOR DR. TURBO........hello, iv been reading a lot of your posts and I even made this account to day so I could get your opinion lol and this subject is pretty much my same situation. I have a 408 Lq9 in an 02 Camaro that currently has a rear mount set up with a masterpower t76 t4 with a 1.06ar. I want to move everything up front and I feel that turbo maybe to small. I've talked to comp turbo and the recommended the CT43XR which is a 80mm compressor and a 92mm turbine t4 with a 1.15ar. iv also looked at the BW stuff and I seem like they're hard to beat for the money, and I forced inductions recommend their gt80, but those to look rather large in physical size and I'm trying to avoid cutting the car if I have to. I'd like to keep the radiator in the factor location, but if it boils down to having to do some cutting then I'll just do it. just your input would be nice and thanks for your time too, and also this is a street car that probably gets driven a lot more then raced so I'm willing to sacrifice some top end power to keep my low end with the fastest spool time possible. thank you
Old 01-14-2017, 08:12 PM
necrocannibal's Avatar
I'm running a T4 S480 96mm wheel 1.25 exhaust and it made 842 on 16 psi. Spool isn't bad at all.
Quick Reply: turbo sizing for a 408?
