Thinking about putting a d1 kit together myself need help
Ok, what all do i need? I was looking at the aster bracket, obviously a D1 reverse rotation, Im going with a fmic, what bov should i use? Boost controller? etc?
Big red.
After your bracket/hardware, head unit, fmic. Then
Radiator hold down, fans and shroud, crank pulley/pinning kit, belt, blower pulley.
Look into a meth kit also, that will get a nice kit started, then feed it enough fuel
I might not put the screws to it right away but id build it so all id have to do is tweak the tune and change pulleys. I was planning on moving my radiator so i can clear a better hat and use stock fans.
I'm subscribing.
I've been thinking seriously about doing the same thing ever since I saw the kit that Sean sold. I'm kicking myself for not jumping on that, I'm sure that it would have saved either of us a ton of $$ to pick it up from him.
What are you thinking of doing about your radiator? I'm thinking of either standing up my stocker or doing a Griffin radiator set up. I'll be doing a custom FMIC anyway, might as well do both at the same time.
Anyway, hopefully you'll post any parts list type info that you discover. I'm sure that you and I aren't the only ones planning this type of set up after seeing that one from Sean on the board.
Maybe we can get a mini-GP put together on a head unit / parts package and save a few bucks.
